Old 07-23-2011, 12:09 AM   #1
FickleFinn
12 bolt code
I have a line on a 12 bolt 3.73 rear end from a '67 C10.
The seller says it has a code of HE 7 29 W - I can't seem to find this number.
Hope someone can help.
FickleFinn is offline   Reply With Quote
Old 07-24-2011, 01:54 AM   #2
FickleFinn
Re: 12 bolt code
I bought the rear end, gonna pick it up tomorrow.
Old 07-24-2011, 10:27 PM   #3
Livrat
Member #1049
Livrat's Avatar
Re: 12 bolt code
Double check the code when you pick it up as the code "HE" comes up as a 1965 3:73 non posi 1/2 ton axle.
There is no "HE" code for 1967 but if upon further inspection it turns out to be "HB" instead it is a 3:07 ratio non posi.
Livrat is offline   Reply With Quote
Old 07-25-2011, 12:50 AM   #4
FickleFinn
Re: 12 bolt code
It is a 3.73 as the ring has 41 11 on it. the mounts all look correct for my '67.
I checked the code when I picked it up and it is HE 7 29 W.
Tomorrow I will begin to clean it up and will measure everything to make sure it fits!!
