I bought a buffing wheel and some polishing creme. Whats the proper way to apply and do this onto my grill? Do i just apply the creme with a rag, left it haze, and then buff it off?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
What type of "polishing cream" did you buy, is it in a toothpaste tube or ??? and what is the "brand name"??? Doug
Meguiar's Medium Cut Cleaner
Meguiar's Foam Polishing Pad
Hmmm, I've never used Meguiar's before so I'm not sure about that one. Are the GMC grills aluminum also? Doug
Recovering Truck Driver
Any rubbing/polishing compound I've ever used, it works best if you put the compound on the wheel, squirt the area to be polished with a squirt bottle of water and buff at a slow speed, adding water as needed.......the water does most of the work for you and without it, you bake the compound and it's a bear to get off and leaves blotches in your finish. If it's pitted very bad, you're in for a long haul. I spent about 12 hours polishing a set of fuel tanks for my Peterbilt when I painted it.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
