Old 07-23-2011, 08:45 PM   #1
FLcustom10
Distributor hold-down bracket?
Should it be installed curved up or curved down? Does this look right?
FLcustom10 is offline   Reply With Quote
Old 07-23-2011, 08:53 PM   #2
69heavychevy
69heavychevy's Avatar
Re: Distributor hold-down bracket?
down
69heavychevy is offline   Reply With Quote
Old 07-23-2011, 09:12 PM   #3
lil hoodlum
lil hoodlum's Avatar
Your question confuses me. The top part curves up and the bottom part curves down.
But yes, I do believe you have it installed corectly. Just add you bolt and your golden!
Keith
lil hoodlum is offline   Reply With Quote
Old 07-23-2011, 09:20 PM   #4
bbadfred
bbadfred
bbadfred's Avatar
Curve up so that the bolt and hold down put even pressure on the dist flange and the manifold boss. So it does not have to be super tight to hold the dist from rotating and change the timing.
bbadfred is offline   Reply With Quote
Old 07-23-2011, 09:51 PM   #5
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
picture 2 looks to be correct, it should be arched if you were to look at it from a side view and the bolt would try to flatten out the arch as it is tightened down.
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 07-23-2011, 10:05 PM   #6
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
to me it looks like pic 2 is correct with the rust on the under side of the bolt head .
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-23-2011, 10:07 PM   #7
FLcustom10
Thanks guys.
Old 07-23-2011, 11:51 PM   #8
Lee H
Lee H's Avatar
To be clear the curve or crown should be up.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-24-2011, 03:32 AM   #9
fastwillie 696969
~Rest In Peace~
this would be a good question for mechanic A or mechanic B for the ASE test
Old 07-24-2011, 08:29 AM   #10
Monty
the convex or 'bumps' should be down. they are the contact points with the manifold and distributer. that is how the engineers controll the location of the pressure points, even with casting variations and tolerance stacking...
each leg of the distributor 'fork' often has a crown or radius facing the same way (down) as the bump on the manifold leg of the clamp. this puts down pressure on two points 180* from each other on the dist collar.
picture #2 is the right way
Monty is offline   Reply With Quote
Old 07-24-2011, 08:57 AM   #11
FLcustom10
I'd be mechanic 'C' Fastwillie! Good explanations.
