Old 07-23-2011, 11:50 PM   #1
manimal
manimal's Avatar
1T GVW and 3/4T GVW?
I have a '73 C30 std cab single rear wheel 1ton the GVW is 8200lbs, I also have a '77 C20 std cab and the GVW is the same as the 1t....8200lbs??????? Why is that? I thought the 1t would have a higher GVW...?
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 07-24-2011, 12:00 AM   #2
timpage
Re: 1T GVW and 3/4T GVW?
I don't have an 'official' answer (and this is as much opinion as anything, sure more will chime in...), but I've learned there are many factors in determining the gvw on our trucks. The axles are one factor, all having thier own weight ratings. Springs also are a factor (number of leafs, size of leafs, different coil springs for 2wd's, etc). I think even brakes sizes have a bit of a factor. Thats my thoughts. I've ran into simular setup, where my '87 V-10 had a 6400 lb. gvw vs. the '85 GMC K2500 parts truck I bought for a 3/4 ton axle swap with a 6600 lb. gvw.
timpage is offline   Reply With Quote
Old 07-24-2011, 10:21 AM   #3
mdb
It's a mystery. I have 9 leaf springs per side on my 76 C25 and heavy duty front coils (and axles to match) but still only a gvw of 6400... I think a lot of it depends on whether or not the original owner paid for a higher gvw option, like a Camper Special.
mdb is offline   Reply With Quote
Old 07-24-2011, 10:40 AM   #4
Your41Plague12
Your41Plague12's Avatar
My '83 K20 had 9 leaf springs plus an overload in the rear, and the standard springs up front. My GVW was 8,600 lbs.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 07-24-2011, 11:37 AM   #5
manimal
manimal's Avatar
Now my '77 is a Silveado Camper Special and the '73 is a no frills Custom 30
-Lance
Old 07-24-2011, 12:23 PM   #6
mdb
Yeah the Camper Special option bumps the GVW up. In another thread a guy was saying he had the exact same axles, springs, etc as a Camper Special but since that option wasn't paid for his GVW was lower.
Old 07-24-2011, 12:52 PM   #7
Redcap
GVW is a pretty arbitrary number...
Redcap is offline   Reply With Quote
Old 07-24-2011, 04:30 PM   #8
timpage
In a way kinda sums up my long winded answer LOL...
Old 07-24-2011, 08:06 PM   #9
manimal
manimal's Avatar
I was just shocked to see my 3/4t was the same as a 1t.
-Lance
Old 07-27-2011, 01:58 AM   #10
4x4chase
Your GVW is affected by brakes and tires. Both your trucks run the same brakes I bet, unless one is a hydroboost. TRUE one ton trucks used hydroboost and dual rear wheels. The duals will greatly increase your GVW as per the sidewall ratings. Hope this helps.
4x4chase is offline   Reply With Quote
