Old 07-24-2011, 02:23 AM   #1
Spot1984
Rear Coilover or not?
70 chevy short box. It has a 383 just north of 500 hp and 500 ft lbs. I want to lower the truck 4/6 but I know from past experience that lowering springs are too stiff. I want to street/strip this truck and need good weight transfer. 12 bolt(c clip eliminators, 4.10 gears, welded tubes, and will be installing a anti roll bar. Will this thing hook with the original coil/shock setup or do I need to install rear coil overs. Also I will be running stock trailing arms with adjustable bracket on the crossmember.
1970 Chevy C10 shortbox- 454
1970 Chevy Nova- 383
1987 Grand National
Spot1984 is offline   Reply With Quote
Old 07-24-2011, 07:59 AM   #2
LONGHAIR
Re: Rear Coilover or not?
If you intend to race it more than "just once in a while", coil-overs may be the ticket. They are far more adjustable/tunable. You can soften it to your liking and change the ride height easily too.
Just be aware that the original mounts were never designed to hold the entire weight of the truck. They will definitely need to be modified/strengthened.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-26-2011, 04:13 PM   #3
craig@ridetech.com
Formerly LSC71
I agree, but you could also put a set of lowered spring along with a really good adjustable shock that will make a huge difference as well, but the coil over will be easier to dial in, especially if you get a good set with adjustable shocks.
craig@ridetech.com is offline   Reply With Quote
Old 07-26-2011, 04:48 PM   #4
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i had my fab man do this to mine 12 bolt
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-26-2011, 05:36 PM   #5
robnolimit
robnolimit's Avatar
Coil-over is probably a better bet. Now that I said that, be carefull, you can't talk to regular race car guys, camaro stuff won't hook up on your truck. You'll need to move the trailing arm mounts (chassis) up appx the same amount that you lower the back. (6"?) Next thing, you need a long shock to make it work. If the back of your truck wieghs 1400 lbs (put it on a diet, lol) thats 700 lbs per side. You want 5" of static spring compression at ride hieght, thats 140 lbs/in spring rate. Use 150's, on a 5" stroke shock body. what you need to do is use 14" long spring, and compress it appx 2 1/2" to a 11 1/2" free hieght when the shock is full open. Then, at ride hieght, the spring will compress another 2 1/2" (1/2 of the 5" of shock stroke), and you will have 5" of spring compression at ride hieght. I would spend the $$ on a set of coil-overs that have both rebound and dampening adjustment. Properly set up, this rear will run 10.20's on a 10" slick. We have a couple of trucks around here on that set up.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
