Old 07-24-2011, 02:37 AM   #1
kanuck
Using 4x4 cab on 2 wheeler
Was wondering if there are any other differences in the cabs besides the raised tranny hump and hole in the tranny tunnel?
I do have one thing I will have to deal with.......
Name:  july 22, 2011 036.jpg
Size:  30.9 KB anyone have a lowered truck with roof lights?
Name:  july 22, 2011 013.jpg
Size:  67.1 KB .....Or am I going to have to fill them?
'70 Malibu with 383 stroker/T350
'56 SWB Mercury pickup..under construction
'67 Firebird Convertible...all done stock
'70 LWB 350 on propane...beater
'69 LWB 350/T400 body restored
kanuck is offline   Reply With Quote
Old 07-24-2011, 07:16 AM   #2
GM72K10
Next!
GM72K10's Avatar
Re: Using 4x4 cab on 2 wheeler
No difference, nice looking cab btw.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 07-24-2011, 09:05 AM   #3
VegasBruce
VegasBruce's Avatar
Yep, the cab will bolt right up. As far as the lights go, it all depends on how you set the truck up.
Bruce
73 Stepside, 74 Blazer, 75 1 Ton, 66 Barracuda and a 05 Electraglide DD
http://i56.photobucket.com/albums/g1...Rusti192-1.jpg
VegasBruce is offline   Reply With Quote
Old 07-24-2011, 09:37 AM   #4
liftlawssuck
liftlawssuck's Avatar
It's not a truck unless it has roof lights. I think all trucks should have roof lights. Just me though.
liftlawssuck is offline   Reply With Quote
Old 07-24-2011, 10:30 AM   #5
BigBlocksRule
^ must be, I like to shave mine for a smooth look, same on the tailgate.
BigBlocksRule is offline   Reply With Quote
Old 07-24-2011, 10:35 AM   #6
Your41Plague12
Your41Plague12's Avatar
Keep the roof lights, send me the cab moldings
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 07-24-2011, 10:51 AM   #7
mooseknuckles
mooseknuckles's Avatar
no roof lights.....unless it's a dually!
mooseknuckles is offline   Reply With Quote
Old 07-24-2011, 01:15 PM   #8
Chlsnk
Chlsnk's Avatar
I think a slammed shortbed 73-80 would look awesome with those lights.
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 07-24-2011, 03:01 PM   #9
Jonboy
Slots go on anything!
...or a Peterbilt.
1974 Jimmy- 5.3/4L80e/NP241
Old 07-24-2011, 11:36 PM   #10
str8axle55
I agree, they look cool on these trucks.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 07-25-2011, 01:21 PM   #11
Pop's C-10
Pop's C-10's Avatar
I like cab lights..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 02-12-2012, 03:45 PM   #12
clemsparks
I found this thread in a search because I've been wondering about cab differences between 4x4 and 2 wheel drive. I think I read here that there is no difference. Is that correct?
Because I need to replace a cab or two on my trucks (I've got a dually 2wd and a 4x4) and want to make sure I source a replacement cab that can work.
Can anyone explain any differences that did exist between cabs on '73-'87 trucks (whether it was specific to 4wd or otherwise).
Thanks!
Clem
1989 Shorbed 2WD project
1983 K20 Longbed workhorse
clemsparks is offline   Reply With Quote
Old 02-12-2012, 04:00 PM   #13
GM72K10
Next!
GM72K10's Avatar
If you can't find one with a high hump reuse the one from your donor truck.
86 K30 CUCV M1028A1
Old 02-12-2012, 04:31 PM   #14
clemsparks
Cool...so you're saying 4x4 had high-tunnel and 2wd had low tunnel? (My trucks aren't in the same place, so I can compare at the moment). Is the tunnel bolt in or is it a cut-n-weld operation? (personally, my plan is to find a cab to restore while driving the truck...then swap it later).
Thanks,
Clem
Old 02-12-2012, 07:18 PM   #15
GM72K10
Next!
GM72K10's Avatar
Thanks,
Clem
Depends on the year and model of truck as to whether it has a bolt in hump or not.
86 K30 CUCV M1028A1
