Old 07-24-2011, 02:49 AM   #1
Lippyp
English Chevy Owner
Lippyp's Avatar
More bolt sizes and water pump question
This time timing chain/Cam cover, I took my water pump off yesterday to clean it up and paint it and found a couple of missing bolts in the timing chain/cam cover, what size are they? I'm guessing its 1/4"-20 but I'm probably wide of the mark. Is there any document anywhere that lists all the different bolts used in a SBC to save me bothering you lot all the time?
Secondly, should the nose of the waterpump where the shaft comes out be packed with grease or was it just the accumulated crud of ages? If so do I need proper waterpump grease?
As always, thanks guys.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 07-24-2011, 02:55 AM   #2
Pop's C-10
Pop's C-10's Avatar
Re: More bolt sizes and water pump question
you are right on tha bolt size & that is jus crud, you don't have to use grease on tha water pump.
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 07-24-2011, 03:02 AM   #3
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
pick up an arp accessory bolt kit, I got a stainless bolt kit shipped to northern canada for under $100 and the black ones are a bit cheaper. The kit has everything for the whole motor externally and comes all sperately labeled
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
