Junior Member
![]() Join Date: Feb 2004
Anyone ever replace just the clutch on the AC compressor in a 67-72 pickup? It is a Frigidaire model and is or was original. The shaft still spins in the compresser but the clutch smoked.
Bill Toothaker 72 K20 FSLB 63K FS:86 Mercedes 560SL 63 Ford F100 51 Willy's Jeep station wagon w/64 289 Studebaker 68 Honda SL90 1500 miles Chevy 6 cyl street rod 2011 Nissan Murano cross cabriolet Cabins for Rent Lake Winnipasaukee, NH |
Re: 67-72 AC clutch for compressor
It is pretty easy if you have the right tools. You will need a puller that threads into the front of the hub, and some snap ring pliers. Remove the nut from the shaft, pull the hub, then remove the 2 snap rings that hold on the clutch and coil.
"Negative people always seem to have a problem for every solution" |
Junior Member
Great, thanks Anyone have a good contact to buy one, I wnat to make sure i get the right one.
when i had mine replaced it was available at local parts store. carquest was the store i got mine i believe most others wood have it too
