Old 07-24-2011, 02:24 PM   #1
mknittle
mknittle's Avatar
how did you do your swinging pedals?
I am getting to the point where I need to make up a brace to tie the brake master cylinder/ steering column and pedals together.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 07-25-2011, 03:08 AM   #2
parkwood
parkwood's Avatar
Re: how did you do your swinging pedals?
I think speedway, or Jeg's sells a swinging pedal set up.. we put one in a car not to long ago and it worked out nice
I don't live that far from you if i can help.. give me a PM and i'll give you my cell number..
parkwood is offline   Reply With Quote
Old 07-25-2011, 04:13 PM   #3
skip99
skip99's Avatar
just did this..
http://67-72chevytrucks.com/vboard/s...d.php?t=475788
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 07-26-2011, 11:14 PM   #4
drivea55
drivea55's Avatar
go to bone yard, cut a newer one out with the power booster and section of firewall.
trim and mate it in.
IMO
Brian
current project;
1950 GMC "Junk Yard Dawg"
http://67-72chevytrucks.com/vboard/s...d.php?t=635960
___________________________________________
SOLD to "ONEBADFIVEFIVE"
http://67-72chevytrucks.com/vboard/s...d.php?t=436406
drivea55 is offline   Reply With Quote
Old 07-27-2011, 11:04 AM   #5
wildearp
wildearp's Avatar
The donor was a european car (friend works in a collision shop), perhaps a jetta. I used a 3/16" plate for support just by the firewall. I was going to add a few more bolts through the firewall, but they weren't necessary. At the top of the photo is a 1" wide by 3/16" thick bar that ties the assembly to one bolt on the steering column drop, that is tied to the dash. It really firms things up nicely. Just to the right is the F1 cowl vent handle, which clears everything nicely.
Photo is a 48 Ford F1, but you get the concept.....
The switch was normally closed which will work well for cruise control, but not for brake wiring. The assembly is set up for two switches and I added a normally open GM brake light switch to do my wiring.
On the firewall side is a CPP dual master cylinder with 1" bore, no booster, and it has an integrated proportioning valve. I highly recommend this part.
wildearp is offline   Reply With Quote
Old 07-27-2011, 11:06 AM   #6
mknittle
mknittle's Avatar
thanks guys, It looks like I will have to make one out of spare parts.
Brian, That was the original idea but Murphy's law is in place here. It would be easy to do just that if I were going to run one of my turbo 400s but I am am going to Run a 4 m21 Muncie or Bw T10.
I am using some of the Pontiac parts that I have from the GTOs I used to mess around with.At this point I have a 76 camaro clip pontaic 400 the {freshest motor} I have 3 400s 3 455s and A couple 350s
The problem now is getting the brake pedal on the right side of the steering column.
http://67-72chevytrucks.com/vboard/s...d.php?t=474288
Mark
My GMC build.
Old 07-27-2011, 03:46 PM   #7
mknittle
mknittle's Avatar
I think I have figured it out. I have a steering column brace from a 70 skylark/chevelle I can widen it 2"at the pivot. Then cut out the stock pivot tube from a caprice brake pedal that drops on the right. Then weld it 2” to the right on 25 wall DOM that fits the stock gm bushings. then make a drop 2” to the left in front of the master cylinder.
I will have to make a clutch pedal like the Chevelle has but with a different push rod pivot so it will push downward instead of forward. The clutch bell crank will have it be fabricated also. Fun stuff
Mark
My GMC build.
Old 07-27-2011, 03:50 PM   #8
mknittle
mknittle's Avatar
P.S. .25DOM and I have most of the parts. but I need to finnish my steering column first.
Mark
My GMC build.
Old 07-28-2011, 10:11 PM   #9
Dan Bowles
AD Addict
I used S10 set up for my '54.
Dan Bowles is offline   Reply With Quote
Old 07-28-2011, 10:19 PM   #10
mknittle
mknittle's Avatar
Does the s10 setup straddle the steering column? And does it use a hydro clutch?
Mark
My GMC build.
