Old 07-25-2011, 01:00 AM   #1
true74enduro
do you guys have giggle in your column
i have a 85 k10 lwb 350 w 700r4. i still have giggle in my steering wheel, even after tightening the reverse torqs on my column. any ideas.
true74enduro is offline   Reply With Quote
Old 07-25-2011, 01:36 AM   #2
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Re: do you guys have giggle in your column
Dunno, mine doesn't laugh. Can you get a video of yours doing this?
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 07-25-2011, 08:19 AM   #3
BigBlocksRule
Nope, but mine has a full-blown belly laugh when I open the gas cap at a station...
If it's a tilt wheel, the screws are probably loose on the tilt mechanism.
BigBlocksRule is offline   Reply With Quote
Old 07-25-2011, 10:57 AM   #4
notyo_cheez
Cool Re: do you guys have giggle in your column
Rag joint bad? Made a big difference when I changed the one in the old Ford I used to own. You'll need a helper.
notyo_cheez is offline   Reply With Quote
Old 07-26-2011, 08:14 PM   #5
true74enduro
sorry guys and gals i forgot to tell you what ive done. my i tore my column apart to fix my washer fluid problem. then after finding out it was just my wiper delay. i then tightened my reverse torqs screws on the tilt universal joint and locktit them. but now i still have the same problem.
