Old 07-25-2011, 09:13 AM   #1
Rochlow
Brake booster/MC problem
I've driven my truck around the block and notice that there is brake fluid coming from between the master cylinder and the booster. Is there suppose to be a gasket between the two. What kind of problem does this indicate? Push rod adjusted to much?
Rochlow is offline   Reply With Quote
Old 07-25-2011, 09:27 AM   #2
mdaven@aol.com
Re: Brake booster/MC problem
Sounds like your MC has a leaking seal. Check fluid levels. Either rebuild or replace.
mdaven@aol.com is offline   Reply With Quote
Old 07-25-2011, 09:31 AM   #3
Richard H.
Spanked once
Richard H.'s Avatar
No fluid should come out the back ,the piston seals are worn.
The ole 350 budget build.
Richard H. is offline   Reply With Quote
Old 07-25-2011, 09:51 AM   #4
Rochlow
Forgot to mention that both are brand new with maybe 2-3 miles on them..
Old 07-25-2011, 12:11 PM   #5
cdowns
cdowns's Avatar
make sure the leak is not a bad gasket seal on the cover of the master cylinder// i see lots of the new replacements especially the chrome ones leak
Old 07-25-2011, 12:41 PM   #6
Rochlow
Actually there is fluid all around the M/C itself.. on the front and back..
Old 07-25-2011, 02:06 PM   #7
clear
Also check brake line fittings and make sure the are not leaking.
clear is offline   Reply With Quote
