Old 07-25-2011, 10:48 AM   #1
NicoSlam
tilt column advice
Over the weekend I found an original tilt column for my 69 SWB. The lever and positions seemed tight but once the tilt is engaged, the whole section that tilts had about a 1/2" play up and down. Can this be fixed? I never opened one up before and hate to spend the money if its not repairable. pics would be great. The seller told me it needed to be tightened internally but i'm not sure on that. The gear selector and the housing it connects to looked good. thanks for the advice.
NicoSlam is offline   Reply With Quote
Old 07-25-2011, 03:30 PM   #2
YBNORML
YBNORML's Avatar
Re: tilt column advice
There is a member on here, I think his name is kevsclassics. He rebuilds columns I bet he would be able to help.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 07-25-2011, 03:33 PM   #3
JOHNORO
oldschoolblazer@yahoo.com
JOHNORO's Avatar
yep Kevin is the man
http://67-72chevytrucks.com/vboard/member.php?u=28095
JOHNORO is offline   Reply With Quote
Old 07-25-2011, 04:49 PM   #4
70shortfleet
70shortfleet's Avatar
Sound like it needs to be taken apart! There are 4 screws that need to be tightened and to get to them the upper housing has to come off. I don't have any diagrams, but I have seen them posted here before. I have had many of these apart and if you've never worked on one they can be a little tricky! If you PM I can tell you more in detail
70shortfleet is offline   Reply With Quote
Old 07-25-2011, 05:53 PM   #5
lil hoodlum
lil hoodlum's Avatar
70shortfleet knows what he is talking about.
I spent around two weeks trying to rebuild my girlfriends tilt comlumn out of a 1991 chevy half ton. I got it apart after having to buy a few specialty tools necessary and tighten the four screws. I couldn't quite get it back together like it should and gave up after many many many tries of disassembly/re-assembly. I just ended up getting her a rebuilt one from columnsgalore.com
Good luck,
Keith
lil hoodlum is offline   Reply With Quote
