When ordering carpet low or high hump which do i have?
I am fixing to order my carpet for my 72 C-10 and it asks high or low hump.Which one would i have and what's the difference?
Re: When ordering carpet low or high hump which do i have?
I believe the 4WD and floor shift models were high hump. Everything else would be a low hump. It's about a 2 inch difference in height.
I assumed since my cab was off a 2wd truck that I needed the low hump. I ordered it and tore the old carpet out only to find a patched hole in the hump from a floor shifter. So I have the low hump carpet in a high hump truck which means it was a real stretch just to reach the door sills and theres about a 1 inch gap in the upper left and right of the cab. |
2wd also were available with high humps too ... easiest way to tell the difference is the high hump bolts in
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
This is how you tell which "Hump" your 67-72 Chevy/GMC Pickup Truck, Blazer, Suburban or Panel has and it is information that you will need when you are ordering sound deadener, carpet, or vinyl floor mats from us.
This is a list of 67-72 Pickups, Blazers, Suburbans, and Panels that were stock with a "Low Hump": All 2 wheel drives with a 6 cylinder engine and a 3 speed manual or automatic transmissions. All 2 wheel drives with a small block V-8 and a 3 speed manual or automatic transmissions. This is a list of 67-72 Pickups, Blazers, Suburbans, and Panels that were stock with a "High Hump" All 2 wheel drives with a Big Block V-8. (Doesn't matter which transmission) All 2 wheel drives with 4 speed manual transmissions. All 4 wheel drives. (Doesn't matter what engine size or which transmission) *Note: All "High Humps" are bolted to the floor and all "Low Humps" were actually formed as part of the floor. Quoted right from my website. Here is a link: http://www.classicheartbeat.com/high_low_humps.htm WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
According to LMC, the low humps were about 4" tall and the high ones were 6" in the center.
Roadtrip!
![]() Join Date: Feb 2003
If it bolts in, it is a high hump. If it is part of the floor, it is a low.
Wes, i had a 72 cheyenne 402/ 3 speed column shift with a low hump. Just thought i would throw that out there for you...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#7 | |
