Shiming the pwr steering pump out? Everything on same pulley?
hey all, my pwr steering pump doesnt line up with my mian pulley wheel. It lines up right in the middle of the 2 groves on my (harmonic balancer?) there is an extra unused groove in the main pulley (harmonic balancer?) but someone told me i can shim out my pwr steering pump to make the groove for the pulley line up with the one that the alternator etc is running on. is this a good idea, or should i keep on my hunt looking for a pulley that somehow recesses the groove of my pwr steering pulley back? any input appreciated. thanks!
I am a Referee of life.
Re: Shiming the pwr steering pump out? Everything on same pulley?
You should give some details.What engine? What Water pump?Maybe a pic.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Cruzin
i have always used a separate belt for the power steering, best i can say with what info i have.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
sorry, small block 350, 70 chevy c20. not sure on the water pump?
My PS pump pulley pumps line up with the outermost groove of the crank pulley and run separate belts. What side is your alternator on, the driver's side as was original?
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
Because your alternator is on the passenger side, you probable have a newer (73 up) 350 with a long water pump as opposed to the original which would have had a short water pump. Someone on here who has dealt with this type of non standard setup can probably tell you what power steering pump pulley you will need to get it to line up with the crank pulley. I wouldn't recommend shimming your pump out. If it is an original pump bracket, it will bolt to the left lower front of the block (drivers's side) and the motor mount's front bolt. Therefore, you can't shim it forward or backwards. Note: You will need a double crank pulley. PS should have a separate v belt.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 Last edited by rsavage; 07-29-2011 at 07:21 AM. |
