Old 07-25-2011, 02:16 PM   #1
McMurray76
Spring Perch ??????
I am the proud owner of a rusted out 77 K20 driver and a solid 86 C20 parts donor. Does anyone out there know if I can replace the rusty spring perches from the 77 K20 with the good ones from the 86 C20?
McMurray76 is offline   Reply With Quote
Old 07-25-2011, 09:38 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: Spring Perch ??????
the perches on the axle have to be cut off the ones on the frame are rivited on and are a little lowerthan the 4x4 so you would get a little lift out of it.
If you are talking about the ones on the axle than you could just swap the axle out if the gears are the same ratio.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 07-26-2011, 11:27 AM   #3
McMurray76
I'm concerned about the forward ones on the frame. Could I use a piece of plate steel welded to the frame then re-attach the perch to the plate to off-set the difference in height? Thanks.
Old 07-27-2011, 04:03 PM   #4
McMurray76
Is there anyplace I can get re-pops?
Old 07-27-2011, 05:48 PM   #5
trout
are you talking bout the hangers on the frame? or were the rearend bolts the the leaf that little plat???
Edited by staff
trout is offline   Reply With Quote
Old 07-28-2011, 11:39 AM   #6
McMurray76
The forward hanger on the frame.
Old 07-28-2011, 02:10 PM   #7
trout
yea they should be the same
Edited by staff
Old 08-04-2011, 02:03 PM   #8
McMurray76
Thanks!
