Old 07-25-2011, 02:59 PM   #1
Tmwoodall
Brake Conversion Rear
Is it worth the cost? Seems like $500 from CPP (for my 72 C10 Frame) is as about as cheap as it gets. I have my factory drums rebuilt and ready to roll, but if I'll see a huge performance increase adding rear disc's I'd like to do it now while my frame is naked.
Anyone care to push me heavily one way or the other? If so is there a far superior kit for around the same price (give or take ~$150)?
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
Old 07-25-2011, 09:30 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Brake Conversion Rear
I don't think there is a performance advantage.
Just looks.
Unless you spend the big bucks with companies like Wlwood and Baer, for their large diameter kits.
(which also require large diameter wheels).
My opinion.
Keith
Convert to disc brakes.
Old 07-25-2011, 10:19 PM   #3
JOHNORO
oldschoolblazer@yahoo.com
JOHNORO's Avatar
you can get away with running rear drums it if you are running solid type Wheels...But if you are going with wheels that have big openings you should go Disc.
Cpp rear disc upgrade was well worth it for me ...
JOHNORO is offline   Reply With Quote
Old 07-25-2011, 10:52 PM   #4
Tmwoodall
That is what I was thinking: aesthetics equals a huge gain. Performance, not so much. I'll probably roll the drums for now and then add discs later one when less things are begging for money. Afterall I will have some open air 20's (C5, 338, or similar).
Thanks for the input.
