Old 07-25-2011, 03:43 PM   #1
KellerMAC
KellerMAC's Avatar
Sloppy Steering - Help
Finishing up my frame-off restoration and we did not touch the front end suspension or the steering wheel shaft. We thought we would address that once we could drive the truck and see what it needs - well, we are at that place and the steering wheel has a lot of slack or slop in it. You can move the steering wheel left and right very easily without moving the tires. This is the case both sitting still and rolling.
What normally causes this problem on a 72 C10 long bed with power steering, so I can head in the right direction? Pitman arm, tie rods, steering shaft, steering box, power steering pump, power steering pump belt, etc?
Thanks in advance for all assistance in this matter.
KellerMac
Texas - Don't Let The Size Scare You!
KellerMAC is offline   Reply With Quote
Old 07-25-2011, 09:33 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Sloppy Steering - Help
I would look at everything.
Steering box, pitman arm, idler arm, inner and outer tie rods, ball joints, and control arm bushings.
Keith
Convert to disc brakes.
Old 07-25-2011, 09:53 PM   #3
rob32472
X2 from above
rob32472 is offline   Reply With Quote
Old 07-25-2011, 10:20 PM   #4
lilpoindexter
lilpoindexter's Avatar
I completly re-did the front end on my '78. I couldn't believe all the tie rods, ball joints were tight...They all had greaseable fittings, and the previous owner loved to lube it up.
The only place I had slop was in the box itself.
I don't think you can go wrong just replacing every bushing/ ball joint/ rag joint, etc in the front.
lilpoindexter is offline   Reply With Quote
