07-25-2011, 06:08 PM | #1 |
Which Rear bags with trailing arms
Hello guys I'm a new member but I have been following builds on this site for a while. I just got a 68 swb and I'm about to bag it and I need to know what brand and size bag works the best in the rear when bolting the bag directly to the trailing arm and frame with a notch. I'm gonna do it this way temporarily until I can tear into it and do a nice 4 link setup. Any other advice is welcome.
Thanks a lot in advance for any info! Posted via Mobile Device |
07-25-2011, 06:10 PM | #2 |
Re: Which Rear bags with trailing arms
I, and a lot of guys, like Slam Specialties RE7's.
07-25-2011, 06:50 PM | #3 |
Firestone F6781/255c or Slam Specialties RE-6's as the 1st choice (or similar sized different brand dbl convoluted bags) or...... Firestone F6873/224c or Slam RE-7's as the 2nd choice.
The difference being the larger bags require less air psi for similar heights. It basically depends on the exact set-up & ride height intended to determine which is optimum.
07-25-2011, 07:01 PM | #4 |
I'm planning on running a relatively low ride hight. I also was wondering do u need cups up front or is there some other way to get as low as possible without spindles or dropmember. I will be doing something more extreme later but just want to get low as possible for now. Also does anyone make drop spindles for 6lug drums?
07-25-2011, 07:56 PM | #5 | |
Even if you do something 'extreme' later, drop spindles are typically part of the equation. They're money well spent/invested in the combination of parts. There are no current manufacturers that make a drop spindle for drum brake applications. Some guys opt to set the bags deeper into the front lower control arms by recessing/welding a section of pipe w/a large enough diameter so that the bag cannot rub against any metal (typically 8" dia pipe minimum) while being flush w/both the top & bottom surfaces of the arm.
07-26-2011, 10:06 AM | #6 |
An alternative to drop spindles for keeping drums and getting lower is stepped lower arms. I'd go with the spindles myself.
07-26-2011, 09:34 PM | #7 |
Here's my buddys (shortbed70 on here). Firestone 2600's w/ a 1 1/2" "bag cup" on the top
http://www.youtube.com/user/shortbed.../8/_fC7d5wOP44 |
07-27-2011, 10:53 AM | #8 |
Thanks for the replies guys. I got some parts on the way and hopefully I'll get started this weekend. I'll take pics and maybe start a build thread if anybody wants me to.
11-24-2012, 07:25 PM | #9 |
VA72C10
would love to see some pics of your truck...from your avatar looks like you've got it bagged now?
Looking for a 67-72 swb or blazer project in or around VA. |
11-25-2012, 11:27 PM | #10 |
i did get it bagged. at first i just cupped the lowers and put bags on the stock trailing arms. i have since put spindles and disc brakes in the front and a notch and wishbone 3 link in the back. next i think im going to go with some tubular control arms and 'z' the front or maybe a dropmember if i can hit the lottery. ill put some pictures up as soon as i can figure out how to get them on here.
- '68 C-10 swb bagged - '71 Cheyenne swb |
11-26-2012, 09:47 AM | #11 |
What bags did you end up going with? and can you post pics of the rear set up. thanks
1968 chevy c10 lwb, 250 inline6, 4 speed, |
11-27-2012, 11:51 PM | #12 |
I went with dominator 2600s. They worked out well, but i really didnt get to put many miles on it before i tore it apart again to notch and link it. This is how the truck sat layed out with this setup. no notch and just cupped lowers up front.
11-27-2012, 11:58 PM | #13 |
VA72C10
Thanks for the pics! Gives me a good idea of the final stance of my shop truck.
11-28-2012, 12:20 AM | #14 |
The new rear setup i went with is a wishbone 3 link tat Nate at porterbuilt fabbed up for me. i told him i wanted something different and i like a wishbone and this is what i got! its exactly what i wanted. i made the bridge, bag plates, and front wishbone crossmember. i think it turned out pterry good. The only thing i dont like is that i dont get much lift with bag over axle, but its ok.
11-28-2012, 12:47 AM | #15 |
I'm in love with your truck! Do you have a build thread? Perfect colors and that wish bone is awesome!
'71 GMC pickup; "Ashley," |
11-28-2012, 01:27 AM | #16 |
I dont have a build thread. I guess I need to start one. thanks for the compliments!
11-28-2012, 01:37 AM | #17 |
Heres a few updated pics. Its still not finished but maybe one day!
11-28-2012, 03:04 AM | #18 |
you can change your lower link bars and put the bags on them to gain more lift.
bag on axle is great for towing |
11-28-2012, 09:52 AM | #19 |
Heres a couple underhood pics
11-28-2012, 10:14 AM | #20 |
C/10 junkie
I love it, looks great!!
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
11-28-2012, 03:44 PM | #21 |
That's a great looking truck!
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
11-28-2012, 05:31 PM | #22 |
Very cool truck. Yes! Start a build thread if you haven't already.
11-28-2012, 07:04 PM | #23 |
I used RE6's in the rear of my '69. RE7's work, too. I had them in the front, but the back required less weight and the kit I bought came with 7's front and 6's rear.
11-29-2012, 09:16 AM | #24 |
im planning on using ss7s, but i cant decide if i want electric valves or manual. pros and cos of each ?
11-29-2012, 04:33 PM | #25 |
I have a cpp c notch in the rear of my 67 and 2" blocks, and was planning on using the ss7 bag also. But with a few people saying they are using the re6's it makes me wonder what is the difference between the ss and re bags?? I also am looking for a fairly low ride height for the daily but may possibly do a little towing with the truck also. I want to just set them up as a manual system with schrader valves for now. Any suggestions on the best bag for my situation??
