Old 07-25-2011, 07:27 PM   #1
cjohnson6772
cjohnson6772's Avatar
Junkyard Keyless?
Anybody got any information on keyless entry and/or power door locks from the junkyard. I remember a thread about someone grabbing a set up from a 90s GM van I think, but I can't find it for anything. Really interested in keyless, but power door locks by themselves are nice too. I just don't want to spend the coin on the aftermarket kits just yet. What can I say? I'm cheap
cjohnson6772 is offline   Reply With Quote
Old 07-25-2011, 07:35 PM   #2
tr69c10
Re: Junkyard Keyless?
I'm in on this to
tr69c10 is offline   Reply With Quote
Old 07-25-2011, 09:17 PM   #3
missinfishin10
Amazed Member
missinfishin10's Avatar
me too...
71 LWB Fleetside
1950 3100 Original Project!
missinfishin10 is offline   Reply With Quote
Old 07-25-2011, 09:40 PM   #4
Codypaul
Codypaul's Avatar
wouldnt you need a bcm to get this to work. Sounds like more trouble then its worth. Besides most older systems relied on IR beam which were pretty awful.
1970 GMC K1500
1993 Chevy K2500
Codypaul is offline   Reply With Quote
Old 07-25-2011, 09:53 PM   #5
Daddy Brim
Daddy Brim's Avatar
I think by the time you go to the junkyard get all of the hardware you need, find a controller that will work you could have got one new for less money and be more reliable. If you look around on line they are not that much.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 07-25-2011, 11:07 PM   #6
eagleuh1
eagleuh1's Avatar
AutoZone sells a kit thats pretty inexpensive. I'm looking at an Avatel unit that has remote start, alarm, door locks and a few other things for about $260. I'd also like to put in the power window module that will lower my power windows to let all this heat out. My wifes Honda has it. Its nice. Good luck with the hunt. Jim.
eagleuh1 is offline   Reply With Quote
Old 07-26-2011, 10:03 PM   #7
wildrib
I bought mine from lmc for $90 and a breeze to install.Junk yard to much trouble!
wildrib is offline   Reply With Quote
Old 07-27-2011, 11:00 AM   #8
Gobbles
Gobbles's Avatar
$90? Good deal!
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 07-27-2011, 11:32 AM   #9
JimmyFloyd
I'm keeping an eye on this. Working on adding Factory Keyless to my dad's 96 K1500, so I might be able to find a solution in my research.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 07-27-2011, 01:23 PM   #10
72SWBURG
Ive got a kit in my checkout cart at LMC right now for my 72 SWB pickup... $69.95
72SWBURG is offline   Reply With Quote
Old 07-27-2011, 01:24 PM   #11
72SWBURG
Work like a charm??
Old 07-27-2011, 01:43 PM   #12
Lemield
Lemield's Avatar
I have the LMC kit in my CST...works GREAT!
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 07-27-2011, 03:17 PM   #13
BLK96
I bought a Viper (Responder 350?) online a year or so ago for $160 shipped from Sonic Electronix. Did not want remote start (it is uprgadeable to that), just an alarm AND remote locks which my 96 did not have. Installed it myself, pretty easy just time consuming. All I had to get additional was 2 relays for the remote door locks.
BLK96 is offline   Reply With Quote
Old 07-27-2011, 10:09 PM   #14
cjohnson6772
Ok ok I guess I must bow to conventional wisdom and purchase a pre-engineered kit. The LMC kit looks good. Did you guys use regular rubber looms through the doors or the contact connection things?
Old 07-28-2011, 08:32 AM   #15
Lemield
Lemield's Avatar
Originally, I ran the wires using a rubber grommet but later decided to put power windows in....so now everything runs in rubber boots that I bought from A1-electric...but I was just on their website and I can't find them anymore....
But I did find something similar on Ebay....
http://cgi.ebay.com/ebaymotors/POWER...-/330432236691
I used a uni-bit type drill bit to make the holes for these...worked pretty well with the doors installed.
Larry
Old 07-28-2011, 03:19 PM   #16
BLK96
I ran wires thru factory grommets for pwr windows/locks on drivers door only. Didnt remove door panel only switchplate
Old 07-28-2011, 03:25 PM   #17
MARKDTN
I don't see why this would not work. Would need one before the body control modules. I would think mid-90s Suburban or van maybe. Hardest thing would be finding a junkyard vehicle with a key fob.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 09-03-2011, 09:52 PM   #18
48cj2a
48cj2a's Avatar
I'm parting my Daughters totalled Pontiac Grand Prix that I bought back from the insurance company and had the same idea.
I already got P/W and P/L stuff from a donor K5 to retrofit, Why can't I pull the Keyless entry stuff from the car and retrofit it?
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline   Reply With Quote
Old 09-03-2011, 10:26 PM   #19
Andy4639
Old member
Andy4639's Avatar
Cool Re: Junkyard Keyless?
I think I will order this tomorrow if they are open.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-04-2011, 03:07 AM   #20
FLEET72
FLEET72's Avatar
There's always Ebay
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
