rust remover & flip kit ??
What is the chemical that is being used to remove rust? Have seen some post with somthing from the eastwood company. Anyone know the name of it?
I picked up a flip kit that a friend had laying around. He never used it. Question is, Does the offset hole go to the front of the leaf or the rear? What is the distance for the offset hole that needs to be drilled in the stock spring plate. thanks
1979 swb 350/350 |
Re: rust remover & flip kit ??
You mite be talking about por-15.
The flipkit perch is to move the axle back about 3/4 to 1". Figure out how far back your disign is and the plate should be the same. Put up a pic of the parts you have I'm sure someone here will have the same one for a bit more guidence.
There was a post earlier about Pepsi to stop rust but most trucks won't fit in a 48 oz bottle ![]() |
A good product for removing rust is Milkstone Acid. You can buy it at Atwoods or I think Tractor Supply may carry it. It's cheap and works great.
after reading on the eastwood web site, i thinks it the fast etch. Anyone ever used it? As far as the flip kit, the block looks like all the rest ive looked at. the hole is not centered in the top. Just wanted to make sure i put the offset in right. The hole to the back is what i was thinking. Tried to find a install sheet on one, but was unable to find on.
1979 swb 350/350 |
Hard to put into words sometimes. What your looking to do when installing the flipkit is move the axle back. This is done to allow more room for he drive shaft when the axle is moved to the top of the spring.
I just cleaned up a set of super rusty headers last night with permatex last night not sure what its called but its a pink jel u apply i.got it at advance auto parts for like $5 its in a little white container
Posted via Mobile Device |
![]() Join Date: Feb 2010
if its a JDM flip kit my instructions say the hole goes towards the front... i just did mine and im happy with the product minus now i have to have a new driveshaft made since i didnt intend to lower the truck when i had my first drishaft made.
If you need any more pictures let me know my beds still off i can get you some if you need them
1980c-10 mybaby |
Just curious does every who does axle flip kit have to get driveshaft made mine is the stock and i wasn't sure if every application required the driveshaft altering
Slots go on anything!
Mine haven't had to be altered.
1974 Jimmy- 5.3/4L80e/NP241 |
So far if im not mistaken im the only one who had to have one made... but my truck came with no drive train so everything from mine is from older cars... 305 motor from a monte carlo munie 4 speed from a nova... had to have a driveshaft made and i measured wrong the first time.... Rule to self from now on... measure 50times have it made once lol
1980c-10 mybaby |
