Old 07-26-2011, 12:17 AM   #1
buttrock slp ss
buttrock slp ss's Avatar
help..
so i bought some 2inch drop spindles on ebay they say they are for 60-87 chevy trucks and say they just need 73-up upper ball joints and 73-up outer tie rods..sooo i pick them up i have a 70 c10 with 72 disc brakes on it my calipers and rotors swapped in and i swapped the upper ball joints and put the outer tie rods in... problems i am having...
-lower a arm is hitting my wheel and so is the outer tie rod perch
-outter tie rod has bigger threads than the older style adjuster sleeve
basically what do i need to do to make this work? inner outer tie rods adjuster sleeves and a centerlink? lower a arms???
buttrock slp ss is offline   Reply With Quote
Old 07-26-2011, 12:23 AM   #2
buttrock slp ss
Re: help..
ps will 75 3/4 ton suspension swap over minus spindels and stuff? sway bar a arms steering and such?
Old 07-26-2011, 05:41 AM   #3
67C10BUB
67C10BUB's Avatar
Re: help..
On the tie rod adjuster, I would give CPP a call. They have billet aluminum ones to adapt just about anything to anything and they look/work way better. They helped me out with a similar issue.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 07-26-2011, 11:38 AM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: help..
This seems to be the problem with suppliers like that. I'm not dissing you for what you bought, but it makes me happy to know that what I bought from ECE was all designed to work with OEM stuff.
But, swapping parts and making stuff work is what hot rodding is all about...and always has been.
Member Nr. 2770
