convert K5 or buy C5?
Well here is the $1,000 question buy an original 71 2wd or convert a 71 K5. The C5 is rough but numbers matching needs alot of work to be done to make drivable. the 71K5 is nice complete but still a project and $1,000 more. what would you do?
Re: convert K5 or buy C5?
I'd buy the original C5. Partly because I hate seeing these trucks cut up, but mainly because an original 2WD fixed up would be worth a lot more than a 4x4 converted to 4x2.
just an fyi.... technically they never made a C5, they were both K5's, just some made 2wd and some 4wd
True. They also never made a C1, 2, 3, 4, and I think 5 Corvette. People just started calling them that and the name stuck.
lol... i think the c4 was the first but could be wrong on that and it be the c5 vette
Hmmmm, If your willing to go with #'s matching restore job to origonal, and not cut it up. go with the C5.. But if you want to do some crazy stuff that is near impossible to get back to origonal. Go with the K5 and convert it. Just my opinion, but with how rare a true C5 is. I would hate to see it chopped and hacked up.. Even if it's friggin awsome..
You can make back most (if not all) your $1000 bucks by selling the axles and trasfer case.. I bought a donor truck 2wd LWB for the frame and running gear and basicaly swapped the bodies. I shortend the 2wd frame for the blazer. But, the LW Box of course didn't fit for the K5 frame. I sold all of it as a running mud and/or 4x4 truck. with a sheet of dimond plate covering the rear wheels. I got my money and then some. The guy that bought it shortend the box somehow and he runs it still. Just saw it a few weeks ago. Hardest part was getting the body mounts put on in the correct place.. Some day I will do a write up. I ran into a bent frame on the new to me 2wd frame, so I had some extra issues. But the Blazer is just waiting for my garage to be cleaned out and start work on her again.. it's been a few to many years.
71 2wd Blazer My build, Restarted 05 Buell firebolt ![]() 94 ![]() No rice for me,,, I'm full ![]() |
lolso no C5!! ive owned a few 4x4 but would like a matching 2wd blazer to my 4x4. been looking for awhile and 2wd seem hard to come by around here. found one that is rough but i think worth saving. still not sold on either one yet. i just know im almost done with my 4x4 build and cant wait to start a 2wd build. need to research more. my thoughts are a mild custom look mostly lowered and fuel injected 350
The LuvShack Garage
Another option is what I did, I took a almost perfectly restored 4wd and
thrashed it and started all over on a 2wd frame. Since mine wasn't a #'s matching frame off resto I didn't care. Now I got a 2wd Square Corvette with a 4wd body. ![]() This would mean buying 2 Blazers, or 1.5 like I did, to achieve the result.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
LUV2XCLR8: I have follwed ur build for awhile love the way it is coming along. i really like that idea i found another 2wd blazer i am working on getting that i would do what u did just need to finish 4x4 build first.
needs more $$$
I think it really depends on your direction of the build. Like some said, if you're going to cut it up to lay frame, no point in getting a more expensive 2wd that needs more work when you'll have to change all the suspension over anyways.
On a side note, my Vin starts with a "C", is that how you can tell it's a "real" 2wd?
1970 2wd Blazer |
#11 | ||
The LuvShack Garage
![]() Quote:
Well i pulled the trigger on the 2wd 71 blazer!! i know need pics go to pick it up tomorrow will take plenty of pics. need to repair the floor previous owner cut it all out and not sure if the truck floor pans work on the blazers or not??
#13 |
Pics!
#14 |
needs more $$$
I read that truck pans work as well as bed floors for the back of the tub.
1970 2wd Blazer |
#15 |
Here are the pics of my new to me 71 2wd its rough but its mine!!
#16 |
Well i decided to buy a 2wd came across this from a friend that has had it for awhile stashed away known him 7 years and never knew about it, until he asked if I wanted buy one. i said looked at it for a good while left came back looked at it 3 more times the floor scares me. but i figured these dont come around that often so i bought it gonna be asking a lot of questions on this one. plans are to get the floor repaired and than pull the body off and clean it all up they notched the rear as u can see cut the frame horns off cut holes the trailing arm crossmember to allow exhaust to be ran through. also has tons of undercoat on the frame so all of that needs to come off. what do u guys think of it?
#17 |
Got any plans for that big window Task Force truck in the background?
#18 |
its not mine its my friends i could ask its been sittin there for awhile
#19 |
Find 1956 Cameos build thread; it'll be helpful and ease the butterflies at the same time. The C in that serial number is gold(imo).
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
#20 |
Sorry, I meant did you have a project in mind for it. I already have a '56 big window.
#21 |
Been collecting sheetmetal for the this beast got all the floor panel patches and a 68 front clip. Just dropped it off at the shop to get the floor repaired.
#22 |
Chop top doors?
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped 1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant |
#23 |
Yeah when I bought it they where going to make it a roadster, and had chopped the doors. I got another set of doors to replace these
Posted via Mobile Device |
#24 |
It looks to me like it has a 6 lug rearend. If it hasn't been swapped, maybe you have a 70?
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC... |
#25 |
Yeah its been swapped he had a set of six lug 20's he wanted to use, wish he hadnt sold the rearend already. It's far from being the perfect project but for the price i couldn't go wrong
