how much for a 14bolt FF at your local pick n pull?
Thinking of doing my drive train and first thing I would like to do is upgrade rear axle and to buy a 14 bolt so any help? Thanks guys
73 Chevy k10 In progress http://67-72chevytrucks.com/vboard/s...52#post3552552 2000 Trans Am, ls1, 6 Spd http://ls1tech.com/forums/appearance...years-old.html |
Re: how much for a 14bolt FF at your local pick n pull?
Don't know about pick-n-pull but around here they go for $200-250 for factory drum brakes and $400-500 with rear disc swap.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
Certified Hobbiest
PnP are around 200 maybe less but theres a couple people on craigslist selling them for round 150-180 complete.
Posted via Mobile Device |
Certified Hobbiest
Scratch that, PnP is 160 for a complete drum break axle
100 bucks buys them here.
They are $50 axles here.
$100-150 all day long for drum. The disc are expensive though, looking at $400-600.
1984 3/4 Ton Reg cab Longbox 4x4, Carbed 350/Turbo 400 Trans/205 T-Case |
Currently Blazerless
They run anywhere from 50 to 200 bucks around here...if you will be hauling with it or running big tires find one with the 13" rear drums
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
bought a disc brake 2500hd rearend with posi for $350.00 couple weeks ago here locally
found one for $80 locally. just needs a axle shaft. you guys think its worth it? freinds says that he usually finds them about 100, pretty commom.
58 Jeep willys pickup 67 K10 4x4- soon to be trail truck ![]() TROUBLE MAKER RACING ![]() "If you can't stand BEHIND our troops, please stand in FRONT of them." |
That sounds reasonable,as long as everything else is there and nothing is torn up inside of it
