72 with a suspected 205 transfer case
#1 - what is the 2wheel and 4 high and 4 low shift pattern on the transfer case - forward - 2wheel high .middle 4wheel high - n - back 4 low? please advise . and there are threads on divorced and not . do all these model always turn the front diff shaft ?
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: 72 with a suspected 205 transfer case
Here's the correct knob for a 205 t-case:
Not sure about your last question.... a 205 turns the front drive shaft only when in 4WD mode.
i did get a shift knob off one of the guys and i thought it to be right for a 205 and had the samr markings as you show but i question the knob when i went to install on the stick and the stick has a smaller thread than the knob so here i am questioning the transfercase . and the truck seems to always be turning the trans shaft to diff so i have not got in the right spot if its a 205 - i will be checking thanks
With the truck in park, jerk the transfer shifter all the way back & forth several times
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
20' Daredevil (Ret)
Found this pic of a 205 t-case:
the 203 transfer turns the front drive shaft all the time. The 203 transfer will not have the small round plate with the 3 bolts in it.
thanks for all the info - i have found 2wheel drive and the transfer case does have the small 3 bolt cover and the drive shaft for the front diff now is rotating by hand - 2 wheel drive . so i do have a 205 but the shifter ball that was onn it is marked marked and when i purchased a ball - marked as shown it is a larger thread diameter - so i have the same shift pattern but wrong shifter or this ball is wrong .
Kid's Mechanic
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. |
