Old 07-26-2011, 03:07 PM   #1
68 IRON
68 IRON's Avatar
Non accessory to accessory?
I would like to change ignition switch with an accessory side....can this be done without too much hassle? My 68 doesnt have an accessory select on it. Everything else is stock. I think it would require a new switch and wiring ( I'm weak on wiring....) Any help will be appreciated.
68 IRON is offline   Reply With Quote
Old 07-26-2011, 03:13 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Non accessory to accessory?
My 68 has acc position....
is yours the 'small' 67 ignition possibly not having acc?
John
1999 Toyota Tacoma 4x4
Old 07-26-2011, 03:40 PM   #3
68 IRON
68 IRON's Avatar
I've read from Longhorn man and Locdoc that 67's and some 68's didn't have accessory on the switch. I've also heard that its as easy as switching the wire from the ignition side to the accessory side once the switch has been changed (with the switch change giving the ability to turn the key in that direction, accessory isolates power to fan, radio etc... and the ignition powers everything) Just wondering if this is correct. Any links that touch on this mod?
Old 07-26-2011, 03:40 PM   #4
chopnchaneled
chopnchaneled's Avatar
My 68 has no acc, its an early one. also has no dimple for power steering.
I know this is not an answer your question, but i would also like to know.
chopnchaneled is offline   Reply With Quote
Old 07-26-2011, 04:21 PM   #5
chewychevy67
i tried an accessory ignition switch in my 67 gmc and the accessory did not power anything. I did not persue it any further so not sure what the solution would be. Could be as simpe as changing a wire position behind the switch but am unsure.
chewychevy67 is offline   Reply With Quote
Old 07-26-2011, 04:53 PM   #6
oldblue1968chevy
my 68 is early too..good luck! locdoc is smart he'll chime in soon
John
Old 07-26-2011, 05:50 PM   #7
Maxxd07
Maxxd07's Avatar
My 68 is the same way so I would like to know as well.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 07-26-2011, 08:05 PM   #8
68 IRON
68 IRON's Avatar
Maxx, what is your assembly number? Just wondering....mine has a dimple and its, I think 130,xxx something. I'll have to check again.
Oldblue, ya them guys are! LocDoc......WHERE ARE YOU?!?!
Old 07-26-2011, 09:10 PM   #9
pritch
pritch's Avatar
It must be more common to not have. I have 3 '68's (well, 2 trucks and a wiring harness) and none of them have the ACC position.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 07-26-2011, 11:34 PM   #10
Maxxd07
Maxxd07's Avatar
I have no clue as of now and it is taking a loooonnnggg nap in the corner of the shop with another pickup infront of the drivers door. It would take me an hour of moving crap just to get to it.
Couple 80s
Couple 70s
One 68
Old 07-27-2011, 12:01 AM   #11
oldblue1968chevy
The ACC is far left about 1030 position, right?
John
Old 07-27-2011, 12:05 AM   #12
Maxxd07
Maxxd07's Avatar
Yea something like that, turn to the left of the off position.
Couple 80s
Couple 70s
One 68
