Old 07-26-2011, 03:33 PM   #1
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
LSX rear gear question
I have the 4.8/4l60e in my truck, was told I had 3.08 gears in my 12bolt truck 3series rear end.
I put a tack in the truck recently and when Im driving down the highway at 70, it shows 2250rpm, which, if you use one of those rear gear calculators show I have a 3.73, am I reading this right or is the tune wrong because I have 27.1" tires ( 255/60r15) and the (?) 3.08 gears with .70 final drive ration on the 4speed auto.
Can yall help me out some?
Thanks,
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-27-2011, 12:56 AM   #2
Super73
Super73's Avatar
Re: LSX rear gear question
Jack up the rear, mark the bottom of the tire and drive shaft with chalk.
3.73 turns of the drive shaf to 1 of the tires means 3.73's.
3.08 turns of the drive shaft to 1 of the tire equals 3.08 gears
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-28-2011, 05:48 PM   #3
TR65
TR65's Avatar
Clyde,
The numbers you give work out to 3.7 (3.73) rear ratio. (as the calculator says)
The engine speed read by the tach should be independent of the tune or the transmission etc. other than maybe setting the ECM to 4 cylinder if the tach doesn't have a switch for that.
The speedometer could be off, just check it with a GPS. It would have to be reading 15 mph slow to give 3.08!!
Best to just check it like super73 says. But if you don't have a posi there is a factor of two involved.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 07-28-2011, 06:03 PM   #4
Clyde65
Clyde65's Avatar
I am going to check it on Monday, 1st day off I have had in 2 months. Ill probably just do the wheel turn thing in the drive.
My tach does have one of those switches, I had it set to 4 cyl as the tuner said to, but it is wrong, have to set it to 8cyl. Why do I listen to those people, why?
Clyde65
Rebuild of Clyde
support our troops!
Old 08-01-2011, 05:17 PM   #5
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
have 3.73's in mine and your rpm looks close to me. My speedo is off tho...and I don't remember what my phone gps reads.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
