Old 07-26-2011, 04:30 PM   #1
pdxirishman
72 GMC Suburban front control arm?
Noticed a lot of vibration in the front end. Discovered what seems to me to be a significant wobble or excessive play in the upper control arms.
Can I simply tighten these up or do I need to upgrade/replace bushing? Possible alignment?
pdxirishman is offline   Reply With Quote
Old 07-26-2011, 04:39 PM   #2
nate_g_2003
nate_g_2003's Avatar
Re: 72 GMC Suburban front control arm?
probably wouldn't hurt to put new bushings in, especially if they are original. an alignment after that is almost required IMO.
-Nathan-
1972 GMC K2500 Suburban "The Project"
2013 GMC Sierra 1500 SLT Z71 "The Daily Driver"
2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD
1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD
2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD
nate_g_2003 is offline   Reply With Quote
Old 07-26-2011, 05:20 PM   #3
SCOTI
SCOTI's Avatar
Where specifically do you feel is it loose? At the shaft to mounting bolts or @ the shaft to bushings?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-26-2011, 09:18 PM   #4
pdxirishman
It looked to be at the shaft to the mounting bolts.
Old 07-26-2011, 09:27 PM   #5
SCOTI
SCOTI's Avatar
If it looks loose there, that suggests some shims fell out. Try to tighten things up & get it aligned.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-27-2011, 02:16 PM   #6
pdxirishman
Will do, Thanks for the help!
