07-26-2011, 05:48 PM | #1 |
Transfer Case Encoder Motor
What a pain this thing is! Changing the part no problem at all. Finding out that it is the problem ! My bad Transfer Case Encoder Motor on my '03 Z71 (92K) caused unbelievable problems.
1. Made the lights on push button case switch go crazy. Blink or just plain went out. 2. Stalling. 3. A/C cycled in and out over and over. 4. No power at all. Foot to floor....25 miles an hour. 5. Shift patterns way outta wack. Wouldn't downshift either. 6. Obviously had no 4WD and SERVICE 4WD code popped up. After all that and a very smart mechanic that I know and about 4 hours making sure there wasn't anything else wrong with any part of the truck the Encoder Motor was found to be the only culprit. Truck threw out 4 codes with one being the CO 327 Encoder Circuit Malfunction. Most of time spent was to make sure the truck didn't have multiple problems so that we were't just throwing parts at it. Changed the part and EVERYTHING back to normal! Thank god for really smart computer mechanics. Just thought I'd share...maybe it'll help someone sometime. |
07-30-2011, 01:17 PM | #2 |
Has more rust than truck...
Re: Transfer Case Encoder Motor
Interesting, glad ya got her fixed.
08-29-2011, 06:11 PM | #3 |
1961 crewcab
this should be a sticky!
chased down a bunch of info, and it seems that this is a very common problem...! been doing lots of google searches to see how to replace this part, 2005 silverado.. is there anything special I should do, or is it just a simple remove and replace?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
08-29-2011, 11:33 PM | #4 |
Not simple as remove/replace. After part is changed it has to be programmed to the trucks computer.
Posted via Mobile Device |
09-08-2011, 11:23 PM | #5 |
They used to sell the encoder itself- you removed the shift motor and split it's case and replaced it- now you buy the rebuilt shift motor and replace it - I've never had to reprogram anything just make sure t-case is in neutral before reinstalling shift motor and the shift motor slides uptight to t-case before tightening or it'll break, hook up the connector and turn on the key- should show light by the "n" push 2wd and shift trans to neutral and it will shift!
Scott 66 chevy short step 327 4speed 67 chevy Short Fleet tpi 350 700r4 72 chevy K10 swb 01 GMC Sierra 01 Pontiac Bonneville |
