Old 07-26-2011, 10:20 PM   #1
ooimpalaoo
ooimpalaoo's Avatar
Lowering spring ??? please help
just a quick ????? can you cut a row out of your rear coils and then weld the top back on to make a shorter coil???/ just a idea not sure if its a good one??? thanx for all the help..my truck is a 1969GMC 910 2wd 250cid and a T5 tranny....6 lug going to 5 lug
ooimpalaoo is offline   Reply With Quote
Old 07-26-2011, 10:42 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Lowering spring ??? please help
The quick answer is no.
Welding on coils springs is not a good idea.
I would suggest buying the correct drop spring.
Keith
Convert to disc brakes.
Old 07-27-2011, 12:54 AM   #3
Wbrown
Wbrown's Avatar
If your short on cash and just wanna lower it for alittle while until you find cheap coils. just buy a set of spring compressors at autozone same effect
Wbrown is offline   Reply With Quote
