Old 07-26-2011, 10:42 PM   #1
bsteele
Brake help
I just installed the new mc, booster and prop valve from CCp. Now trying to hook up the arm to the pedal. Is there some trick to this? The pin comes in contact with the steering column before lining up to the hole in the pedal. How do I get this back in? I saw where some people said to drill a hole one inch down the arm(they said their directions said to do this), but mine did not. HELP!!
bsteele is offline   Reply With Quote
Old 07-27-2011, 07:50 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Brake help
Do you have any pics?
Keith
Convert to disc brakes.
Old 07-27-2011, 12:11 PM   #3
bsteele
Re: Brake help
I finally got it!! I figured out a way to get the push rod to depress enough to get the pin by the steering column and into the pedal. Now I have to attempt to find brake fittings to connect stock lines to the new prop. valve.
Old 07-27-2011, 12:16 PM   #4
lolife99
lolife99's Avatar
Re: Brake help
Just make sure you have a little "free play" in the pedal so your brakes aren't pre-loaded.
I would think 1/8"-1/4" would be enough.
Keith
