07-26-2011, 11:12 PM | #1 |
On a bagged rear diff shouldn't it be able to lean.
I've seen some rear bag set ups that look like they would have a pretty crappy ride.
Like this mini-truck, he would loose traction if he ran over a 2x4 with one wheel. He should at least loosen the jam nuts so it will flex. Shouldn't it be able to lean a good amount for going in driveways and stuff? It seems like it would knock out the bushings after a while. After looking at the prices for heim ends, I could save some money by building like this guy and don't Heim joints transfer the road noise through to the frame?
Some say "The glass is half empty." Some say "The glass is half full." I say "the glass is twice as big as it needs to be, chop it off!!! |
07-26-2011, 11:32 PM | #2 |
Square
Re: On a bagged rear diff shouldn't it be able to lean.
that set up seems like it could lean just fine.
Squarebody Syndicate |
