Old 07-26-2011, 11:38 PM   #1
C10longwb
70 power steering swap
Hey guys I have a 70 c10 Lwb I have converted the front brakes to disc from a 71 setup now I'm considering up dating the steering I'm trying to decide wether I should just replace the sloppy manual box or upgrade it to a power unit. My main question is what all I need to change I know I would have to add a power steering pump and a power steering box but would I have to change the column or will a ps box bolt right up? And would I need to change any of the front suspension will the pitman arm ect... Thanks I'm advance for any advice
C10longwb is offline   Reply With Quote
Old 07-26-2011, 11:53 PM   #2
CHEVY_BOI93
Re: 70 power steering swap
mine already came with a ps box. but im 99% sure it will bolt up to your steering column. no problem there. just make sure you get the correct ps pump. and the installation is a breeze. you dont need to make any adjustments what so ever. POWER STEERING is so much better. =)
CHEVY_BOI93 is offline   Reply With Quote
Old 07-27-2011, 12:00 AM   #3
Dano69c10
Dano69c10's Avatar
PS pitman arm is different than the manual pitman arm.
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 07-27-2011, 12:08 AM   #4
C10longwb
Hey guys thanks for the info I had a feeling it would be pretty much a bolt up but I wanted to check first
