Old 07-27-2011, 01:16 AM   #1
dukcaln
dukcaln's Avatar
72 gas tank relocation ??
I want to relocate my in cab tank to under the bed, is there a kit out there or could I use the tank out of an 87 parts truck my father inlaw has sitting at his house... If I can use that tank from the 87 what would I have to do to accomplish the switch...
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 07-27-2011, 02:16 AM   #2
Hisroth
Re: 72 gas tank relocation ??
I haven't done this yet myself, and I'm sure others will know much more than me.
But from what I've read, the 85 blazer tank fits perfectly in the frame of the 72, straps and everything. I don't know about an 87 pickup tank though.
Hisroth is offline   Reply With Quote
Old 07-27-2011, 11:23 AM   #3
dukcaln
dukcaln's Avatar
ok thanks I hope somebody else will give thier 0.02 on this...thanks for the tip on the blazer tank....maybe if anything I will have to hunt one of those down....
SOLD 1972 chevy c10
Old 07-27-2011, 11:50 AM   #4
Jeffs70
Jeffs70's Avatar
I am not sure about the tank out of your 87 but here are some links with kits
http://www.lmctruck.com/features/cb/CBGTN.htm
http://www.ineedparts.com/auto-parts...rsion-kit.html
http://www.brotherstrucks.com/prodin...number=GTPDS72
Jeffs70 is offline   Reply With Quote
Old 07-27-2011, 02:33 PM   #5
dukcaln
dukcaln's Avatar
Jeff hey thank you...... looks good and at least it is a very managable $$$ investment that I can live with........
SOLD 1972 chevy c10
Old 03-10-2012, 11:56 AM   #6
whiteyandreddy
Hey. Nice trucks. How did your gas tan relocation turn out? Whihc tank did you end up with?
Check out my project: 1972 Chevrolet Stepside- Shortbed
http://67-72chevytrucks.com/vboard/s...d.php?t=392386
. . . . . . . . . . .__
. . . . . ______l__l\___
. . . . .l_[(O)]_____(O)]
whiteyandreddy is offline   Reply With Quote
Old 03-10-2012, 01:41 PM   #7
LEEVON
Moderator
LEEVON's Avatar
I think the blazer tank is a good option for value. There's a member here that makes nice aluminum tanks too. Be aware the filler neck routing for the blazer tank isn't a direct fit and requires some cutting and fab work. I wanted to relocate my tank but at some point came to the conclusion that it's been back there for 40 years working just fine...
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 03-12-2012, 02:18 PM   #8
Lloyd C.
Tired of the fumes in my cab, I utilized the small Blazer tank for my very low 68 stepside. I believe it holds about 17 gallons and doesn't hang down so low that it scrapes on everything. Then I fitted a filler and door assembly from (now get this) a Ford Ranger pickup into the rear of my left rear fender. Works slick. I'd attach a photo if I knew how. Remember, this unit is a non vented system so you must add a vent tube to the gas tank. Just be sure to put plenty of coils in it so that it won't splash out gas when you hammer the throttle.
Lloyd C. is offline   Reply With Quote
Old 03-12-2012, 03:00 PM   #9
turp mcspray
turp mcspray's Avatar
You'll have to use a blazer tank, as the square body pick up tank won't fit anywhere.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
