This ground strap hooks up where?
You can see it bolted to the firewall just above where the clutch rod boot is. This is a 70 K10. It was never hooked up on this truck. It is longer than the one on the passenger side. Thanks.
Roadtrip!
![]() Join Date: Feb 2003
Re: This ground strap hooks up where?
The trucks i have seen, it would be under a valve cover bolt.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Active Member
![]() Join Date: Jul 2007
On my 69 there is a bolt hole behind the head where it attached to. Should be bolt hole on the front and an identical in the backside.
valve cover hold down bolt ...
Old member
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Valve cover bolt
mine was bolted to the back of the head.
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
Thanks, guys. I will go with the valve cover bolt. The passenger side ground was still hooked up when I pulled the original engine, bolted to the back of the head, like alot of you guys said. Hopefully I will see if this thing is going to run by tomorrow.
