Old 07-27-2011, 05:02 PM   #1
Mccoleman830
Mccoleman830's Avatar
HELP.......Truck has major shudder.
I fired up the truck today to discover that my 78 has a major shudder problem. Trying to diagnose the problem has left me clueless. It shudders extremely bad when in reverse, and all drive gears. When placed in park and neutral it still has a slight vibration. I tried to drive it down the street, but while a stop light you have to keep your foot on the gas pedal or it has a violent shake. Any advise where to look at would be great. 1978 GMC K-15 350/350. The only thing ive done lately was get a fill the tank with fuel. I thought it might be bad fuel, but switching tanks from right to left doesn't help at all.
Thanks.
1978 K-15, 350/350, 4.11's, 17" KMC's, 37's.
Mccoleman830 is offline   Reply With Quote
Old 07-27-2011, 05:40 PM   #2
Stepper562
Stepper562's Avatar
Re: HELP.......Truck has major shudder.
try the obvious and most simple thing first like checking how high/low your idle is in park, bad fuel filter if you have one, bad carb, tune up etc...little more ibfo is required in order to diagnose the problem.
Stepper562 is offline   Reply With Quote
Old 07-27-2011, 06:31 PM   #3
ratrod67
ratrod67's Avatar
Sounds like U joint or carrier bearing. Maybe check your transmission mount also.
ratrod67 is offline   Reply With Quote
Old 07-27-2011, 06:35 PM   #4
Eyegore
What Hump?
Eyegore's Avatar
Add motor mounts also.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 07-27-2011, 07:15 PM   #5
rwhit57
rwhit57's Avatar
Could be something as simple as a vacuum line loose. Check things out vacuum lines, plug wires, etc.
rwhit57 is offline   Reply With Quote
Old 07-27-2011, 07:21 PM   #6
HTX86chevy
HTX86chevy's Avatar
x2............... i recently messed with the vacuum lines on mine and it started having the same problem youre having. Check Vacuum lines, i bet you'll solve your prob
HTX86chevy is offline   Reply With Quote
Old 07-27-2011, 08:55 PM   #7
Mccoleman830
More info........while idling in park my tach reads at 800 rpms. When in drive it drops down to 600 rpms. Also checking out my edelbrock 1400 carb, the left side mix screw doesn't affect engine idle. The right side screw does affect engine idle, if that makes since at all. Adjusting fast idle screw and shudder does not go away.
Old 07-27-2011, 08:59 PM   #8
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
are you sure its firing on all 8?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-27-2011, 09:07 PM   #9
71swb4x4
71swb4x4's Avatar
Since you have it at idle you can eliminate the transmission and back.
My "guess" would be that you are missing on a cylinder or more. I would check the distributor/wires/plugs first. Start with the simple things.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-27-2011, 10:59 PM   #10
Mccoleman830
Weird, I just happened to tightened the carb bolts to the intake manifold, and start the truck. After doing that the truck runs perfect. I drove around the block and by the time i got back home it started shuddering again. I'm thinking that maybe I need to re-check all bolts and nuts on the carb and intake. It has been 5-6 years since I've had the intake manifold off. Thanks everyone for your ideas and input.
Old 07-27-2011, 11:23 PM   #11
71swb4x4
71swb4x4's Avatar
Might be a vacuum leak if tightening the bolts helped.
Old 07-28-2011, 06:49 AM   #12
Stepper562
Stepper562's Avatar
Best way to check for leaks around the manifold and carb is to spray around it while running. Listen for a change in idle it'll be an obvious change. Also +1 on the vaccum lines. Check for dry, cracked and disconnected lines. Replace if needed.
Old 07-28-2011, 08:56 AM   #13
71swb4x4
71swb4x4's Avatar
Stepper is saying to spray something flammable, usually people spray carb cleaner.
Old 07-28-2011, 09:35 AM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
check your fan
my 4 blade fan lost one took out my lines master cylinder to the valve on the front crossmember
vibrated after a lot but maybe it would too just before letting go
surprised me it could do that
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-28-2011, 10:01 AM   #15
Stepper562
Stepper562's Avatar
Yep sorry about that...carb cleaner is the best and cheapest way to go. Thx for clearing that up.
Old 07-28-2011, 11:18 AM   #16
amodedude1
amodedude1's Avatar
an UNLIT (lol) propane torch works too, when the propane gas finds a leak your idle speed will audibly change and will narrow down your search, somewhat safer than carb cleaner. Be very careful with carb cleaner, don't do it right after you drove since as they said, it's flammable.
amodedude1 is offline   Reply With Quote
Old 07-28-2011, 02:28 PM   #17
rwhit57
rwhit57's Avatar
Sounds like it's time for a new carb gasket, some vacuum lines, and general tune-up. Snug the intake bolts down don't tighten them hard. Still sounds like vacuum leak to me.
Old 07-29-2011, 05:56 AM   #18
irishman999
irishman999's Avatar
Take a look at the harmonic balancer.
irishman999 is offline   Reply With Quote
Old 07-29-2011, 09:36 PM   #19
Mccoleman830
I'm thinking I have the shudder narrowed down to the carburetor. While spraying carb cleaner around the seams and around the back of my Edelbrock 1400 the truck revs slightly higher. My question is, What is this valve in the picture? I believe it goes to the vacuum source for the transmission. When i took carburetor off I noticed it was loose and bent. Is it even worth replacing this unit? I'm going down to the parts store to get a full rebuild kit for the carburetor and hopefully it will take care of this problem.
Old 07-31-2011, 10:33 PM   #20
motornut
78K & 79C Jimmys
motornut's Avatar
loose and bent.....fixing that can't hurt
yup looks like the vac line for the tranny
John
