Old 07-27-2011, 08:21 PM   #1
1972RedNeck
1972RedNeck's Avatar
Frame Width Differences?
I have been looking at a 20 gallon suburban tank conversion for my '72 3/4 ton 4X4. The tanks are listed as 29" wide. The distance between the bottom frame lip at the back is about 27 1/2". Are 4X4's different? My truck was equipped with a heavy rear spring option. Does this make a difference?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 07-28-2011, 01:00 PM   #2
1972RedNeck
Re: Frame Width Differences?
Can somebody at least measure the distance between the bottom lips of the frame rail at the back so I know if mines different (I think it is).
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 07-28-2011, 02:41 PM   #3
GruntMoanCough
GruntMoanCough's Avatar
The frame's the same width. Measured the tank in a 3/4 ton Sub rolling chassis I've got here.
The main shape of the tank is 26", however, the overall width is 29" including the welded flange, which goes under the frame rail.
In other words, yes, it will fit.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 07-28-2011, 02:52 PM   #4
1972RedNeck
Thanks for clearing up my confusion.
1966 F250 4X4 416
1972 K20 350 4 OTF
