Old 07-28-2011, 12:40 AM   #1
redmonster
redmonster's Avatar
Angry Hate this shtuff
Went to primos house bout twenty minutes away
Coming home engine got so hot blew new upper radiator
Hose
Fresh rebuild whats going on help help
WITNESS
Dont be like me be better than me
redmonster is offline   Reply With Quote
Old 07-28-2011, 12:51 AM   #2
PHAT TONY
PHAT TONY's Avatar
Re: Hate this shtuff
Sounds like an air pocket in the motor; prevents the coolant from circulating properly. Raise the front end high as possible and run the motor till it heats up, be careful though; once the thermostat opens and that air heads out it'll push a ton of HOT antifreeze out as well! I've had to do this a couple times.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 07-28-2011, 01:37 AM   #3
yob2kanobe
yob2kanobe's Avatar
Remove the thermostat and Drill a tiny hole in it to allow trapped air to escape and allow the coolant to contact the thermostat and open it.
yob2kanobe is offline   Reply With Quote
Old 07-28-2011, 06:40 AM   #4
cdowns
cdowns's Avatar
can b lots of things/wrong direction water pump/bad or incorrectly installed thermostat/collapsed lower radiator hose/ a leaky connection not enough coolant/incorrectly installed intake or head gaskets/ bad timing adjustment/rad fan not working properly
those are all fairly common problems
Old 07-28-2011, 01:49 PM   #5
Indyuke
Plus, rebuilt engines running a bit hotter than ones that are broken because of all the surfaces that are establishing a wear pattern. If you have an EGT sensor, you can really tell when the rings seat themselves. The EGT temp will drop like a rock.
Indyuke is offline   Reply With Quote
Old 07-28-2011, 01:52 PM   #6
1970 Bowtie
It's all in the timing
1970 Bowtie's Avatar
1st thing I would do is change the thermostat.
The Dude Abides.
I aint sayin, I'm just sayin.
1970 Bowtie is offline   Reply With Quote
Old 07-28-2011, 09:25 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
did it over heat and blow the hose, or are you assuming it overheated before the hose popped?
Old 07-29-2011, 12:48 AM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Are you runnin' the 40 year old stock original radiator as well?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-29-2011, 01:26 PM   #9
redmonster
redmonster's Avatar
Gary yes the radiator is original but before it went in was acid washed
Longhorn man the upper and lower radiator hoses were brand new after the rebuild
When going one the road sounded like a boiling kettle look at temp gauge was way over h so shut it off popped open hood and bam a small hole in the upper hose
Why did u ask
WITNESS
Old 07-29-2011, 01:32 PM   #10
redmonster
redmonster's Avatar
Took out thermostat replaced hose still running hot y y y
WITNESS
Old 07-29-2011, 02:18 PM   #11
GASoline71
GASoline71's Avatar
Why did u ask
What is "acid washed"? Do you mean "flushed". Most radiator fushes won't get 40 years of crud built up on the core out of the radiator. It might need to either be rodded out or a new radiator.
Longhornman was basically stating that if you didn't notice the overheat before the hose popped... there might be other damage.
Gary
Old 07-29-2011, 03:13 PM   #12
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
His engine may well be overheating, but it shouldn't blow a hose (especially a new one) because of the pressure relief on the radiator cap, which no one has mentioned yet. Try a new stat & rad cap, and make sure you get all the air burped out of the cooling system.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 07-31-2011, 02:44 AM   #13
redmonster
redmonster's Avatar
Angry Re: Hate this shtuff
Would u guys suggest getting a new radiator for the 250 I6 didnt even make it to the store
Bout quarter mile now the drive belt busted
Help
Help
Help
WITNESS
