Old 07-28-2011, 10:58 AM   #1
Desert1957
Desert1957's Avatar
Need a new engine and your advise
My 83 needs a 5.7 long block. Should I replace what's there or go the LS route?
Only thing that complicates my desicion ( other than Money) is that this is my tow vehicle and it has an SM465 manual transmission.
Appreciate any thoughts you guys might have, Thanks in advance.
Desert
Desert1957 is offline   Reply With Quote
Old 07-28-2011, 11:14 AM   #2
veinbar
veinbar's Avatar
Re: Need a new engine and your advise
383 would be the best decision for towing a pulling such a big vehicle around. The LS swap would be amazing, really amazing, but could take ages to complete and twice the money of the 383. Fuel efficiency should be comparable to the 350, maybe better due to improved torque. Just my 2 cents.
veinbar is offline   Reply With Quote
Old 07-28-2011, 11:48 AM   #3
jrcaprai
If you can afford the LS do it.... but I would suggest the Trans replacement as well
jrcaprai is offline   Reply With Quote
Old 07-28-2011, 11:53 AM   #4
tucsonjwt
How much weight and how often are you towing. Personally, I like my SM465 with a gear vendor behind it, but for towing up and down hills it might not be the best. If I were to invest in a modern engine and trans, I think I would look for a newer truck with those items in place, stock from the factory, rather than try to convert my old square.
tucsonjwt is offline   Reply With Quote
Old 07-28-2011, 12:14 PM   #5
Desert1957
Desert1957's Avatar
I have a newer truck (04- Z71) , I love my old "Square Pickups" that's why I'm here.
My 83 Silverado is the work horse, 9200 GVW "Camper Special" 410 gears and Stick , It will tow anything. Race car enclosed trailer weighs about 7000 Lbs, Gets towed about 3 weekends a month.
Desert
Old 07-28-2011, 02:27 PM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
I would just go back to the same 5.7
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 07-31-2011, 05:19 PM   #7
C-10 simplex
i think it boils down to how much time and money you got?
And, realistically, how much driving/towing in miles per month will you do?
The LS is generally superior to the small blocks/big blocks etc and will probably get much better mpg, but will most likely take much longer to complete.
Simplest easiest way would be 350 or 383, but these don't get the mpg that the ls can.
C-10 simplex is offline   Reply With Quote
Old 07-31-2011, 06:00 PM   #8
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
The tried and true 350 you cant go wrong with it. Since you have done towing in the past with this why not just stick to what works
http://www.jegs.com/i/GM-Performance...oductId=752506
The only thing i would add is This to take it into the morden day
the LS is a trend just like the cummins and shortbed crew cab is
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 07-31-2011, 06:02 PM   #9
mooseknuckles
mooseknuckles's Avatar
If I had a choice, LS motor and trans.
mooseknuckles is offline   Reply With Quote
Old 07-31-2011, 06:05 PM   #10
camshaftgsxr
camshaftgsxr's Avatar
if your going to buy a long block get the biggest one (383 406 blah blah) you can, however... LS IS the best option if you have the money
camshaftgsxr is offline   Reply With Quote
