Old 07-28-2011, 12:22 PM   #1
rich67
rich67's Avatar
454 implant
want to put a 75 454 in my 79 4wheel. anyone have a pic of what the towers and mounts should look like. have to change both when going from small block to big block? any help appreciated. thanx, rich
rich67 is offline   Reply With Quote
Old 07-28-2011, 01:09 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: 454 implant
As long as you have the mounts on the block of the 454 you are set, the mounts on the frame are the same.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 07-28-2011, 08:30 PM   #3
cheepin
Re: 454 implant
The only problem I had when I put a 454 in place of a sb400 was I had to use a short bowl fuel pump.I believe it was for a BB in a 70 malibu.The tall bowl hit the frame.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
Old 07-28-2011, 09:33 PM   #4
baclay9
Re: 454 implant
No problem. Everything is the same. Even the clam shell mounts that bolt to the motor.
baclay9 is offline   Reply With Quote
Old 07-28-2011, 10:45 PM   #5
sierra4x4
sierra4x4's Avatar
Re: 454 implant
It is a bolt in. But you will need the short fuel pump. I think I ordered one for a 70 corvette 454. It was the short one but it didn't have the return line but it worked fine. BB and SB engine mounts and frame mounts are the same.
sierra4x4 is offline   Reply With Quote
