Old 07-28-2011, 12:30 PM   #1
clemdaddy
clemdaddy's Avatar
question about factory air
i want to replace the blower motor in a 66 factory air truck. the folks at 'old air products' in texas say that they don't show a listing on the blower motor for factory air but that they are different from the non-air heater motor. something about a bigger mounting flange.
does anybody out there know if later model blower motors will work, if the mounting flange is different? like say 73-82 model trucks.
thanks, clem
clemdaddy is offline   Reply With Quote
Old 07-28-2011, 01:51 PM   #2
64fleetside
Re: question about factory air
Just about any GM heater motor will fit. The fact A/C did use a different one with larger windings, but it's almost impossible to find one. They all bolt up the same, & should be still available from your FLAPS--Four Seasons/Factory Air part # is 35587
64fleetside is offline   Reply With Quote
Old 07-28-2011, 05:44 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
post pics with measurements, gives some of us visually challenged folks a chance to put our .02 in.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-01-2011, 02:03 PM   #4
clemdaddy
clemdaddy's Avatar
just wanted to put this thread to sleep with a happy ending before it slides off into the abyss.
heres the pics for the challenged, just a joke clyde my man. 66 air motor on the right, note cooling hole which has a rubber elbow that also is attached to the firewall box and rotates air around the windings.
and you're right 64 fleetside... the air motor is the same as later suburban motors and is interchangeable.
thanks guys
