Old 07-28-2011, 07:42 PM   #1
Low & Slow
67-72 front clip interchangability?
Thanks to a drunk my 67 is now in need of an entire new clip. Due to time constraints and being in the middle of a move I need this truck working like now.
I will use this thread as a means to chronical the saga of the front end rebuild. My question for you gentlemen is what exactly is the interchangability of the front ends on these trucks? I was told the 67-72 gmc front fenders were the same as 67&68 fenders. Is this correct? Can I use will the front clip from a 67-72 gmc bolt right up? Will a gmc hood work with 67/68 front c10 fenders?
My local junkyard has several options. I just want to pull the panels in the best shape.
Here is the starting point:
Thanks guys!
Low & Slow is offline   Reply With Quote
Old 07-28-2011, 08:01 PM   #2
lowdown72
lowdown72's Avatar
Re: 67-72 front clip interchangability?
67-72 gmc fenders are the same but the 69-72 gmc hood is the same as the 69-72 chevy hood but u can swap the entire clip from the gmc to your truck if that helps any
72 c-10 67 clipped 327 th400
lowdown72 is offline   Reply With Quote
Old 07-28-2011, 08:08 PM   #3
67chevy1series
67chevy1series's Avatar
fenders:
67 chevy = 67 gmc
68 chevy = 68 72 gmc
69 72 chevy = nothing in gmc
67 chevy/gmc or 68 chevy 69 72 will work for 67 68 chevy front clip.
69 72 chevy will work for 69 72 chevy grille
67/68 chevy hood = 67/68 gmc hood
69 72 chevy hood = 69 72 gmc hood
67 68 chevy radiator support doesnt match or work with any other grilles
you can cut off the headlight buckets that are welded in front of the head light holes of a gmc or 69 72 chevy radiator support to have a quick fix. but you wont be able to mount the splash apron like a 67 68 radiator support has the little nuts built in.
67chevy1series is offline   Reply With Quote
Old 07-28-2011, 09:18 PM   #4
skoolbusyeller72
skoolbusyeller72's Avatar
Will a 67/68 hood fit on a 72 with 72 fenders and grill? I thought i seen this somewhere but cant find it...
1972 Custom 10 LWB
1973 V8 Vega wagon
1925 Model T Wrecker
1913 Model T Speedster
http://s181.photobucket.com/albums/x...07/72skoolbus/
skoolbusyeller72 is offline   Reply With Quote
Old 07-28-2011, 09:25 PM   #5
lowdown72
lowdown72's Avatar
yea but it takes some modifacation i think rockcrawlin has a write up on it
Old 07-28-2011, 09:59 PM   #6
71swb4x4
71swb4x4's Avatar
The short answer is no. It would take serious modification involving cutting and welding.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-28-2011, 10:01 PM   #7
71swb4x4
71swb4x4's Avatar
Low & Slow what do you want to end up with? Do you want it to look like it did before your accident? Do you just want solid metal with no concern for the year and style? What are your skills?
1967 fenders are an animal of their own because of the lack of marker lights. If you get a 68 Chevy or GMC or the 69-72 GMC fenders they will work the your hood and grille but you will have to weld the marker light hole shut.
You can pull any 67-72 front clip whole and it will bolt up to your truck.
Old 08-10-2011, 08:35 AM   #8
Low & Slow
Basically I want the first now rotted front end I can find. I don't mind the markers in the fenders at all, the problem is finding a complete front from one three options, GMC, 67-68 C10, or 69-72 C10.
I can pick up a 71 set of fenders, hood, and billet grille for $250 but need to then find the rad support and the headlight brackets.
Or a complete GMC front end with some minor rot in the lower finder corners for $200. But I would have to pull it all off in the junkyard by myself. The search continues!
Old 09-11-2013, 12:32 PM   #9
Beetle
Beetle's Avatar
So GMC Paul's has GMC radiator supports in stock. If I end up buyin this 69 C/10 I want to buy.... I want 4 headlights. What do I need for the GMC swap? 68 Chevy fenders, the radiator support, splash apron, wire, grille, lights (head and turn), bumper, tailgate...
Do I have it all?
Jason
TEAM C10 HOT ROD POWER TOUR
689 Short Step
68 Step
Trucks Sold: 70 GMC, 72 K5
Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins
Beetle is offline   Reply With Quote
