Old 07-28-2011, 07:54 PM   #1
CowboyProtectionUnit
CowboyProtectionUnit's Avatar
Parts Transferability... Half Ton to 1-Ton
OK I realize that the Main Parts Springs, Front Differential Inards, and axles and Such aren't transferable... but What if any Parts are... Here's What I'm doing... Taking this...... my 87-88 GMC 2wd Crew Cab Dually and Converting it to a 4wd.... Its Been Suggested that I find an buy a Donor Truck... and I'm curious if I need to be looking for a 1-ton 4x4 or since I'm planning on rebuilding the front differential I can get away with a half ton or 34 ton 4x4 since I tend to be finding More of them just lying around here lol
Thanks again Ya'll
Eric "Target" Sherwood
Professional Bullfighter For Hire
God Bless and Gods Speed!
TheCowBoyProtectionUnit@yahoo.com
http://www.facebook.com/pages/Eric-T...59496227444241
CowboyProtectionUnit is offline   Reply With Quote
Old 07-28-2011, 08:07 PM   #2
Re: Parts Transferability... Half Ton to 1-Ton
Mainly I'm wondering about 4x4 parts...... Mounting Brackets and Such....
Old 07-29-2011, 09:59 AM   #3
madcow75
madcow75's Avatar
1/2, 3/4, and 1 ton leaf spring hangers are all different offsets. What brackets are you wodering about. Front leaf spring is all the same thou. My 1 ton frame was 5/8" not as high in the front motor mount section so I had to modify my motor mounts to fit. All 1/2 and 3/4 tons are the same up front thou.
madcow75 is offline   Reply With Quote
Old 07-29-2011, 10:34 AM   #4
dropd80s
dropd80s's Avatar
Yeah the engine crossmember and motor mounts may be a little different on a 1/2 or 3/4 ton, but the leaf sprinf mounting points should be the same from 1/2 to 3/4 to 1 ton.
"I'm Dirk Diggler enough to own and operate a vehicle of this caliber" -veinbar
Dropped and LS Swapped SWB 87 Build Thread
dropd80s is offline   Reply With Quote
Old 07-29-2011, 10:56 AM   #5
VegasBruce
VegasBruce's Avatar
The 1 ton uses different spring hangers in the rear, than the 1/2 and 3/4 ton. The front are the same I think. This place is good for aftermarket hangers and such. http://diy4x.com/ You could use a 3/4 ton front and adapters for the stock wheels and leave the dually rear.
Bruce
73 Stepside, 74 Blazer, 75 1 Ton, 66 Barracuda and a 05 Electraglide DD
http://i56.photobucket.com/albums/g1...Rusti192-1.jpg
VegasBruce is offline   Reply With Quote
Old 07-29-2011, 04:09 PM   #6
Mattman2010
Mattman2010's Avatar
1/2 and 3/4 ton rear spring hangers are the same, 1 tons use different rear spring hangers. All front hangers are the same. 1/2, 3/4, or 1 ton 4wd engine mounts/cross member will not fit in the 1 ton 2wd frame. You will have to either modify the 2wd mounts and make a cross member, or you will have to build your own engine mounts/cross member.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 07-31-2011, 11:28 PM   #7
Thanks Guys! I'm Planning on Swapping the 454 with a Cummins So I already knew I had To Swap engine mounts and Crossmembers.... I know of a few Sites Online that Sell Crossmembers an was Just going to Order one for a 4x4 when I did it.... The "brackets" I was talking about were the Spring Hangers.... SO everyone's Comments were very helpful!!!!
Old 07-31-2011, 11:46 PM   #8
O I just realized nobody has Addressed the Front differential Internals... Could I pick up a 1/2 or 3/4 ton Front differential and completely gut it and replace with the Internals I want IE Detriot Lockers.....
Old 08-01-2011, 12:26 AM   #9
Pyrotechnic
Pyrotechnic's Avatar
With the Cummins I'd go with the beefiest front diff you can get. That's a heavy engine, I wouldn't want that kind of weight up front on a half ton front axle. Most of all, I definitely wouldn't want a half ton rear axle behind a Cummins. Your best bet is to get 1 ton running gear.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 08-01-2011, 12:46 AM   #10
I've Gotta 1-ton Rear end.... the Picture of the Truck in the first post is mine.... But what I'm asking is can I Pull ALL the Internals out of say the 1/2 front end differential and Swap them out with Detroit Lockers 1 ton axles and Detroit Locker 1 ton internals...
Old 08-01-2011, 10:25 AM   #11
blakeduren
You can't put "1 ton" i.e. dana 60 internals inside a "1/2 ton" i.e. dana 44 housing.
blakeduren is offline   Reply With Quote
Old 08-01-2011, 08:22 PM   #12
Thanks! Thats finishs up my questions! LOL
