07-28-2011, 08:41 PM | #1 |
1966 blinker issue
My left side blinker stops and goes solid when I apply my brakes. I thought the problem was in the broken plastic blinker switch in the steering wheel so I replaced it, no fix.
I have checked the bulbs and cleaned up all of the connections on everything I can find. The wiring seem so simple, is there a ground I'm missing or something? 1966 C-10 350 powerglide |
07-28-2011, 11:45 PM | #2 |
Re: 1966 blinker issue
the most common ground problem I've run into is the grounding of the front blinker bezels (or actually, the housings I guess I should say). Seems all my blinker problems have ended up being traced there. Good luck - it's a stinky problem - Lord I hate chasing electrical gremlins...
