07-28-2011, 10:16 PM | #1 |
Confused on lower steering column
Hi, I have a 69 c10 I6 250. When I bought the truck a few mos ago it had an auto steering column that replaced the 3 on tree. I am installing power steering set up and have an issue. I removed the steering wheel to adjust the column due to the turn signal lever pointing straight up. When i removed the intermediate shaft, the main shaft fell out? Is this supposed to be that loose? Bearing ring seems ok. Does the spring and washer hold this into the column or am i missing something to hold it up in the tube? Thanks
07-28-2011, 10:33 PM | #2 |
Re: Confused ion lower steering column
07-28-2011, 11:13 PM | #3 |
thanks. i did search but didn't come across that one. It did remind me i am missing the turn signal cancel cam. Thanks Again
07-29-2011, 07:57 AM | #4 |
Re: Confused on lower steering column
The shaft is held in place with a spring and washer which rests against the coupler as can be seen in the picture.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
07-29-2011, 09:56 AM | #5 |
Thanks Jim. nice photo
08-03-2011, 03:09 PM | #6 |
Success! thanks guys
11-16-2011, 06:30 PM | #7 |
Bakenaz,
I have to replace my lower bearing... Can you separate the shafts at that junction in the picture without having to remove the steering wheel? Can you let me know what your procedure was to disassemble / reassemble? I would appreciate it, thanks! |
