Old 07-28-2011, 10:21 PM   #1
SS Delux
SS Delux's Avatar
4.3L hesitating when "cold"
Ill get right into it, when i start my truck up for the first time after i let it cool down completly (overnight or 8 hour shift at work) it seems to hesitate on takeoff and during any acceleration. It is getting pretty bad and i want this fixed soon since it is my DD and my only vehicle. what could cause this ?
P.S. It is a 1987 with tbi and a 4 speed stick.
SS Delux is offline   Reply With Quote
Old 07-29-2011, 08:48 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 4.3L hesitating when "cold"
anyone?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 07-29-2011, 12:27 PM   #3
classic70
classic70's Avatar
Check base timing first. make sure it is at zero with the plug unplugged (under the booster)
classic70 is offline   Reply With Quote
Old 07-29-2011, 10:04 PM   #4
SS Delux
SS Delux's Avatar
I timed it before I put it on the road a few weeks ago and I just checked the timing again, it is at zero when the plug is undone. Could it be an old cap, rotor, plugs and wires ? They are about 1.5 years old but the truck was sitting for a bit. How often do you replace them ?
Old 07-30-2011, 02:20 AM   #5
Gregs71
After the truck is warm does it run fine???? I have an '87 with a 350 that does the same thing when cold, but when it warms up its fine. I figure its a sensor that is not telling the motor its "cold".
1995 GMC 4x4 1/2 ton
1999 Jeep Wrangler w/ 33's
68 camaro 350/350
1987 Chevy 3/4 ton 4x4
Suzuki DRZ 400s Dual Sport
1971 chevy long bed 2x4
194? Dodge 2.5 ton
1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455
1989 Chevy V30 crewcab dually 454/TH400
Gregs71 is offline   Reply With Quote
Old 08-01-2011, 11:44 PM   #6
SS Delux
SS Delux's Avatar
Yea, its runs great after it gets to running temp. What sensor could that be ? I already replaced the water temp sender in the manifold.
Old 08-02-2011, 12:21 AM   #7
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Remove and clean the EGR and air idle valves. The O2 sensor could be failing. Have you tried to pully any codes?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 08-02-2011, 09:51 AM   #8
BoredJoe
I have the same problem in mine, It Is really annoying, hope you get it worked out so I can to lol
BoredJoe is offline   Reply With Quote
Old 08-02-2011, 06:16 PM   #9
SS Delux
SS Delux's Avatar
how do I clean the EGR ? and what are the air idle valves ? There is a new 02 sensor in it.
Old 08-02-2011, 06:28 PM   #10
brianthelion02
Overdrive club
brianthelion02's Avatar
Could be a weak fuel pump!Happened to me before!
1971 c-10
1951 3100 chevy
1970 chevy c-30 Sold!
brianthelion02 is offline   Reply With Quote
Old 08-02-2011, 10:06 PM   #11
gchemist
gchemist's Avatar
Remove the EGR valve. Using compressed air, blow out all the black carbon. Use a solvent cleaner and small brush for large carbon deposits. Check for operation. The air idle valve is on the throttle body. It is held by two small screws. Remove it and clean the rubber end. It may be distorted or ruptured. Check for operation. It will set itself after you start it up. There is a procedure to set it too. Check with www.autozone.com. The fix it your self area had factory directions, pictures and diagrams.
