![]() Join Date: Sep 2008
Rear sleeve bag options
For a 69 1/2 ton with trailing arms, mounted right over the axle.
I've been planning on using Firestones, but are there better options out there? The Truck will see light to moderate tow loads (for a 1/2 ton truck). Firestone 9000 and call it done? Thanks |
Formerly LSC71
Re: Rear sleeve bag options
Keep in mind that the 9000 has a ride height of 9". Mounting them on top of the axle will not allow for much drop. Typically I suggest mounting them in front or rear of the axle tube so you can drop them down some to get the lower height. I'm a little curious though, since your truck has trailing arms, why not just put a double convoluted air spring in place of the coil spring?
word.... what the craig just said
