Old 07-29-2011, 01:18 AM   #1
steven49
1949 long bed
I have a 49 5 window long bed 8 lug that I want to convert to 5 or 6 lug the cheapest way posible. Does any one have a suggestion
steven49 is offline   Reply With Quote
Old 07-29-2011, 11:33 PM   #2
solidaxel
solidaxel's Avatar
Re: 1949 long bed
Have the same question with a customers truck.
What options are available IF we want to keep the 8 lug axle and drive shaft?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-30-2011, 04:25 PM   #3
bmnk
bmnk's Avatar
Re: 1949 long bed
I posted a similar question a week or so ago, and was pointed toward some good information. I ended up finding some additional information....
" One series of the famous “drop out” GM differentials was used between 1946 and 1972 on 3/4 and 1 tons. The complete assembly (often called a pumpkin) will interchange during these years with no alteration.
The highest gearing in this series is the 4.10 ratio and is found in most 1967-72 3/4 tons with automatic transmissions. Therefore, those “low gear blues” often associated with 3/4 and 1 tons during the late 1940’s and 1950’s can be greatly improved with no visible exterior changes. Originally these older trucks had a ratio of 4.57 in the 3/4 tons and 5.14 in the 1 tons.
Once a 4.10 pumpkin is located (usually in a local wrecking yard) it is a basic interchange requiring little more than new gaskets and gear grease. Your truck’s personality is now changed! "
I hope that helps.....I think I'm going that route, as I also wanted my 3/4 ton to keep the 8 lug axle.
bmnk is offline   Reply With Quote
Old 07-30-2011, 05:51 PM   #4
solidaxel
solidaxel's Avatar
Re: 1949 long bed
Thanks Good Info
LS 3 4L70E
Old 07-30-2011, 06:14 PM   #5
mr48chev
mr48chev's Avatar
Re: 1949 long bed
I've seen a couple of 3/4 ton AD trucks converted to 1/2 ton by swapping the front axle and springs for an AD truck front axle. Then swapping a 55,56,57 pickup axle under the rear if you want to stay with the six lugs.
For five lug you can use 53/54 Chevy car hubs and backing plates on the front and a rear end with a matching bolt pattern. I had a 61 Chev car rear end under the 48 with 15x7 rally wheels and it was a good fit but lots of brackets to cut off. Later I ran a 66 Impala 12 bolt that was a bit wide with the 14x8.5 rims and N-50 tires. That one also has a lot of brackets hanging off it that have to be cut off.
Old 07-30-2011, 11:19 PM   #6
reinmeister1951
Re: 1949 long bed
The 48 1 ton long box I just bought has disk brakes & 5 bolt hubs but I don't know what they used to do it.
Doug
reinmeister1951 is offline   Reply With Quote
