What springs do I remove ?
I have a 1969 chevy 3/4 ton and it has 10 springs in the pack 3 of which are flat bars and thick. my question is which of these springs do i remove if I am lowering it.
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: What springs do I remove ?
Pics would help
Fabricate till you "puke"
I used the main leaf,+ the next 3 below it on my longhorn(tossed the rest)...crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
its all about the +6 inches
hey Al, when you did the back of your longhorn... was that all you did? Can you haul anything anymore?
#5 | |
bummer.
i am looking for the impossible. Cheap (as in dirt cheap) low able to haul |
#7 | |
Thanks for all you guess's reply's.
1972 C/20
I left the top three leafs in my c/20. I am debating whether adding one more. For now, I am going to install air shocks to give back a little hauling capacity. Right now, it rides like a cadillac. Also, I flipped the axle and installed C-notches.
Thanks guys I removed the middle 3 and it looks and rides like a dream, I left the three flat springs on the bottom so I can still haul stuff. All of your info has helped a ton and I will post a pic soon.
