Old 07-29-2011, 02:10 PM   #1
Groyd
Groyd's Avatar
A/T Cooling 4L60E
Here's the situation. I have a 4l60E and need the A/T lines that run to the radiator. The radiator is out of a 67' Mustang. I've been having trouble figuring out the thread size on the radiator. I found a bolt that fit it and took it to Lowe's and it fit in the 3/8-24 slot. I bought a universal kit from inlinetube and its so universal that it doesn't work on anything. ha. It has 5/16" tubing(to small for the tranny and too large for the radiator). The lines from the tranny were 3/8" with 1/4" threads.
So here's the question(s):
1. How do I run the lines? Braided hose, steel lines and bend them?
2.What fittings would work best?(This is my main question)
3. Would I be better off just running the lines from the transmission to an external transmission cooler? and if so, would a heat sink cooler work, because I don't have room up front for another tube/fin type cooler? Or can you mount a tube/fin on the frame like the heat sink coolers?
1951 Chevy 3100/S-10:
http://67-72chevytrucks.com/vboard/s...d.php?t=406072
1957 Chevy 3200
1971 2WD Blazer - Sold
Groyd is offline   Reply With Quote
Old 07-29-2011, 03:52 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: A/T Cooling 4L60E
the 4l60e has -6 fittings for cooling. 3/8's tubing should be fine, that is basically what -6 is anyway.
I think the stock rad should need 1/2-20 fittings, summit would probably have what you need.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-29-2011, 03:59 PM   #3
Groyd
Groyd's Avatar
Thanks for the reply. I ended up calling Summit's help line and I got talked into a small stacked plate tranny cooler that should fit above my a/c condenser. Thanks for answering my question though.
-Matt
1957 Chevy 3200
Old 07-29-2011, 04:24 PM   #4
Clyde65
Clyde65's Avatar
I see alot of guys using the long vaned style cooler and then run it through the rad cooler too, always better to over kill cool if your in a hot climate. Good luck Matt!
Clyde65
Rebuild of Clyde
support our troops!
Old 07-31-2011, 07:47 PM   #5
clinebarger
For the Ford radiator you need two 1/8" NPT male to 1/2" x 20 female SAE flare fitting. http://store.fedhillusa.com/ad5br.aspx
For the trans you need two 1/4" NPSM male to 1/2" x 20 female SAE flare fitting, This factory equipment on TH350,TH400,700R4, & early 2 peice 4L60Es with 5/16" cooler lines. Wreaking yard or spare trans laying around are the best solutions, The Aftermarket thinks the threads in the trans are 1/4" NPT, So if you buy some make SURE they are 1/4" NPSM.
clinebarger is offline   Reply With Quote
Old 07-31-2011, 09:42 PM   #6
Groyd
Groyd's Avatar
Thank you for the very specific answer. That's why I ask questions on this board. I always know that there is someone out there who has the right info. I know a lot of other people have used this radiator as well. So this should some others too.
Thanks,
Matt
1957 Chevy 3200
Old 08-01-2011, 08:32 AM   #7
Clyde65
Clyde65's Avatar
for the ford radiator you need two 1/8" npt male to 1/2" x 20 female sae flare fitting. http://store.fedhillusa.com/ad5br.aspx
for the trans you need two 1/4" npsm male to 1/2" x 20 female sae flare fitting, this factory equipment on th350,th400,700r4, & early 2 peice 4l60es with 5/16" cooler lines. Wreaking yard or spare trans laying around are the best solutions, the aftermarket thinks the threads in the trans are 1/4" npt, so if you buy some make sure they are 1/4" npsm.
show off!
Clyde65
Rebuild of Clyde
support our troops!
Old 08-01-2011, 10:19 AM   #8
clinebarger
Originally Posted by Clyde65 View Post
show off!
I was just helping you out on this one John
Old 08-01-2011, 02:38 PM   #9
texastrendz
sorry to hi jack, i have a 4l60e with no lines out of the trans at all. What is the best solution to connect the cooler to the facotry trans fittings? thanks daniel
texastrendz is offline   Reply With Quote
Old 08-01-2011, 02:46 PM   #10
clinebarger
Are you asking how to connect the factory 5/16' cooler lines to the transmission?
Old 08-01-2011, 04:14 PM   #11
Clyde65
Clyde65's Avatar
I know you were Chris, thanks man!
Clyde65
Rebuild of Clyde
support our troops!
Old 08-01-2011, 05:45 PM   #12
texastrendz
I bought a motor/trans with no lines attactched to the trans. Looks like a bubble style flare fitting. Can i convert these fitting to a A/N style fitting to simplify the plumbing. Any help would be great. Thanks Daniel
Old 08-01-2011, 09:00 PM   #13
clinebarger
The fittings on your 4L60E are "quick disconnect" O-ring fittings, They are a bad design.
Replace them with #6 AN male x 1/4" NPSM male fittings http://www.sweetperformance.com/prod...&productId=480
Old 08-02-2011, 10:37 AM   #14
texastrendz
Thanks man, that is exactly what i was looking for. That needs to posted somewhere easy to find. This makes more since to me with the the ease of use of AN fittings.
Old 08-04-2015, 04:43 PM   #15
fast&low
I know this post is old but will the fittings out of a 1988 700r4 fit the 4l60e?
fast&low is offline   Reply With Quote
Old 08-04-2015, 07:13 PM   #16
clinebarger
If the 4L60E is older than '08. The 700R4 fittings wil work
Old 08-04-2015, 07:21 PM   #17
fast&low
Thank you
I'm a little worried the top fitting went on well and tightened up pretty well but the lower went on well but does not stop turning so I put the original back on & no problem?
Old 08-04-2015, 07:45 PM   #18
clinebarger
Originally Posted by fast&low View Post
Thank you
Is the fitting damaged (Threads)? What year is your 4L60E?
Old 08-04-2015, 07:50 PM   #19
fast&low
The fittings have no damage to them whatsoever and the transmission I couldn't tell you because I have the transmission already installed so it's hard to see inside?
Don't know the year of the transmission if you could tell me what numbers to look for I'll go out and look.
It's actually a 4l65e converted into a 4l60e 2WD.
Old 08-04-2015, 08:30 PM   #20
fast&low
Sorry 60e converted into a 65e 2WD
Old 08-04-2015, 10:04 PM   #21
clinebarger
I am going to guess the Thread Locker GM put on the Original Steel fittings is giving you hell, A lot of it stays in the Case Threads.
The Brass Fitting have never been in that Case before...The Threads are not a Perfect match....New ones may be worse!! Manufacturing variances & Tooling play a huge role here.
The fittings out of the 700 need to seat to the Case, Done it hundreds of times & some get real tight before they seat because you are re-activating the thread locker from the heat of the Brass threads reforming to your case.
Old 08-04-2015, 10:32 PM   #22
fast&low
Yeah I understand what your saying & I don't know the year of my Trans but I have been doing a lot of googling lol and something tells me I shouldn't have used my flare fittings & now I probably damage to the threads on my transmission?
And I hope not because my transmission is not a junkyard pull its a upgraded Trans I bought from Just Chevy Trucks to handle the lq9 with no worries.
The original fittings went back on with no problems I just pray to God they don't leak.
Thank you for your time & God bless
Miguel Stevens
Old 08-04-2015, 10:46 PM   #23
clinebarger
You can still use the 700 fittings, But they will be pretty tight before seating!
However I do not want you to twist a fitting off in the Case, Explaining "Feel" over the internet doesn't work to good.
Old 08-04-2015, 10:57 PM   #24
fast&low
No you don't understand the 700 fitting that I tried installing on the lower side got snug then very loose & I say snug because I wasn't hard on it & what I mean by loose it doesn't stop turning.
The good thing is the the OE snap on fitting went back on good & snugged up I'm just afraid to tighten it to hard.
Tomorrow morning I'll go back out and put some liquid Teflon and try tightening it up.
Old 08-04-2015, 11:04 PM   #25
fast&low
clinebarger can you tell me which side is the high-pressure side the lower or the upper side?
