Old 07-29-2011, 03:27 PM   #1
El Campo
El Campo's Avatar
Need help with Z'ing frame
When people Z the frame it is usually behind the front crossmember correct? I lowered the big block one inch and moved it back two inches plus put a deep oil pan on and now am very close to the steering linkage. since the front appears to be sitting a little high for my preference anyways I was wondering if I could Z it in FRONT of the front crossmember. I would obviously have to move cab mounts down a bit but it would fix my clearance issues with the steering plus look lower. Would the moving of the steering linkage down give me bumpsteer issues? Are there things that I am not thinking about that I should be? Also how big of Z do people go? Is an inch viable? Thanks!
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 07-29-2011, 08:54 PM   #2
SCOTI
SCOTI's Avatar
Re: Need help with Z'ing frame
Z-ing the frame "in front of the x-member" will not do anything for suspension drop except possibly move the positioning of the steering gear. What you're describing sounds more like a body drop vs suspension drop (which is why a frame Z is usually done).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-30-2011, 11:24 PM   #3
El Campo
El Campo's Avatar
I understand that it is a body drop and not a suspension drop. I already have 4 inches in the suspension by way of spindles and springs . This is actually what I want to do because it will make my radiator fan shroud line up better and will allow more clearance for my steering linkage. The reason I want to Z it rather than just move the core support brackets down is because the frame would interfere with the cord support if I did that. I should have been more clear on that. What I am wondering is if this will screw with bumpsteer , etc
Hook em Horns!!!
